Old 11-03-2021, 08:12 PM   #1
Conaway2
Conaway2's Avatar
Default Additional ground cable
I would like to add an additional ground cable from the frame to one of the transmission bolts - do any of the vendors sell a suitable cable with a bolt connector at each end, rather than one end with a battery post connector ?
Thanks - Jim
Conaway2 is offline   Reply With Quote
Old 11-03-2021, 08:16 PM   #2
old ugly
old ugly's Avatar
Default Re: Additional ground cable
NAPA or any auto parts store should be able to help you.
about as thick as the one that goes to your starter and
measure before you go.
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
Old 11-03-2021, 09:02 PM   #3
Crankster
Crankster's Avatar
"Custom" good quality battery and ground cables are available in any length or gauge desired with different ring terminal sizes, for not much money. I get them from a guy on eBay.
Crankster is offline   Reply With Quote
Old 11-04-2021, 06:57 AM   #4
Patrick L.
Patrick L.'s Avatar
TSC usually has them. The bigger the better.
Old 11-04-2021, 07:09 AM   #5
nkaminar
nkaminar's Avatar
Marine supply houses have the cable and the connectors to swedge onto the cables. They allow you to use the swedging machine at the store. The marine cables are better quality than the usual automotive cables. Marine wires are tin plated that stops corrosion and there are more wires of small gauge in a cable to make it more flexible.
Old 11-04-2021, 03:22 PM   #6
rotorwrench
rotorwrench's Avatar
I've always made up my own electrical cables since I have the swaging tools. Electrical cable and terminal eyes are available from multiple sources or a person can purchase the flat woven universal ground straps and go that route.
Old 11-04-2021, 06:43 PM   #7
McMimmcs
McMimmcs's Avatar
I always have mine fabricated at a welding shop. Quick, easy and very reasonable!
McMimmcs is offline   Reply With Quote
Old 11-04-2021, 07:37 PM   #8
1931 flamingo
1931 flamingo's Avatar
I believe I got one from Snyder's.
Paul in CT
