Old 01-27-2017, 03:02 PM   #1
roger gurney
Default 1935 model 60
just starting to get my 1935 model 60 cabriolet out of long term storage ready for the road again.
had to have the radiator recored it was blocked solid with silt fitted new exhaust.. rebuilt the carburettor cleaned out jets fitted new accel,r pump kit
removed distributer cleaned points.
but engine missfires will not rev easily when i short out plugs the outer two spark well the inner two spark weekly.
what should the points gaps be
what else could cause the week spark on the inner plugs.
thanks
roger
roger gurney is offline   Reply With Quote
Old 01-27-2017, 05:20 PM   #2
jimTN
Default Re: 1935 model 60
I would recommend setting your points on a dist. machine if you can find someone that has one otherwise a manual KRW dist fixture and lastly by using a ruler. Someone will chime in here on that method. You may have a bad condenser and maybe some bad plug wires leaking in the conduits.
jimTN is offline   Reply With Quote
Old 01-28-2017, 02:36 AM   #3
mercman from oz
mercman from oz's Avatar
Nice looking 1935 Ford Cabriolet.
Old 01-28-2017, 12:52 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
That's a right-hand-drive car. Note No steering wheel, and the outside door lock below handle, as well as step pad on LEFT fender for rumble seat. WHERE is Spalding? DD
Click Links Below
T5 W/TORQUE TUBE
Old 01-28-2017, 01:46 PM   #5
Brian
Brian's Avatar
Not only is it RHD, it's English. Note the headlite lenses and fender mounted side lights
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 01-28-2017, 01:57 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
DUHHHHH........I can't believe I missed those! DD
Click Links Below
T5 W/TORQUE TUBE
Old 01-28-2017, 04:11 PM   #7
mercman from oz
Here is a picture of the 1935 Ford Cabriolet from the original British Ford Sales Catalog. Note the Fender mounted Parking Lights.
Old 01-28-2017, 04:31 PM   #8
KUDZUVIPER
I think Spading is in Lincolnshire, England, due N of London, East central England.
KUDZUVIPER is offline   Reply With Quote
Old 01-28-2017, 05:09 PM   #9
Ian NZ
Ian NZ's Avatar
What model V8 engine is fitted to this 1935 Cabriolet as they had the 4 main bearing V8 -60 engine and the normal 21 stud engine fitted to them.
Ian NZ is offline   Reply With Quote
Old 01-28-2017, 05:13 PM   #10
mercman from oz
That is a very unusual looking front Engine Mount?
Old 01-28-2017, 05:47 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
I believe that's the little 22 horsepower English V8 for '35 or so, similar to the eventual American V8-60. Note Ian's complete engine (pretty snazzy, too) in the pic below. DD
Click Links Below
T5 W/TORQUE TUBE
Old 01-29-2017, 01:08 AM   #12
JM 35 Sedan
JM 35 Sedan's Avatar
Here are some additional posts with pictures of this same car.......
http://www.fordbarn.com/forum/showthread.php?t=92071
http://www.fordbarn.com/forum/showthread.php?t=90971
http://www.fordbarn.com/forum/showthread.php?t=93338
http://www.fordbarn.com/forum/showthread.php?t=91248
http://www.fordbarn.com/forum/showthread.php?t=93336
http://www.fordbarn.com/forum/showthread.php?t=95650
John
Old 01-29-2017, 09:57 PM   #13
rooboy
Merc man......Is that the Merc trev originally owned.....?
Still miss him and our regular "chin wags"......
rooboy is offline   Reply With Quote
Old 01-29-2017, 10:56 PM   #14
JM 35 Sedan
Trev (aka 52merc) is missed by many of us here. We were sending pm's back and forth until his last visit to the hospital. Trev had a 52 Merc that was black with a red top, at least that's what it looked like in his avatar picture. This was one of his last posts so you can see his avatar picture.
http://www.fordbarn.com/forum/showth...ghlight=52merc
John
Old 02-03-2017, 07:45 AM   #15
roger gurney
sorry for not answering questions and thanks for all your replys.
but my father was suddenly taken ill and is in hospital at the moment.
so not much time at the moment
roger.
near spalding
lincolnshire
uk.
Thread Tools
Display Modes
