07-11-2016, 06:58 PM | #1 |
early '31 68b firewall question
Can anyone tell me if this horizontal bracket is original to this car, and if so what is it for??
If at first you don't succeed, skydiving isn't for you! You don't need a parachute to skydive, you only need a parachute to skydive twice. |
07-11-2016, 07:54 PM | #2 |
Re: early '31 68b firewall question
Definitely not original. My guess is that it might have been added to hold aftermarket horns.
Charlie Stephens |
07-11-2016, 08:56 PM | #3 |
Hold the hood open
07-11-2016, 09:28 PM | #4 |
Not original.
Bob 1930 68B |
07-11-2016, 09:34 PM | #5 |
Someone was thoughtful enough to not drill holes in that nice firewall.
Looks like you can pull it and the 2 sided foam tape off quite easily. |
07-11-2016, 09:54 PM | #6 |
07-12-2016, 04:27 AM | #7 |
Either a hair dryer for heat or WD40 sprayed over the bar if double edged tape, should work to help remove the non-original bar.
07-12-2016, 08:18 AM | #8 |
Yes, the piece on the firewall, behind the coil bracket. Thanks for all the reply's. I didn't think it belonged there, and I can't imagine what it would hold with just double sided tape. Anywho, off it comes!
