03-27-2016, 05:30 PM | #1 |
Mitchell for a mid April build 30 Tudor
Mitchell lists 1928-30 and 1930-31 part numbers. Anyone know how to determine which one for a 30 model?
Thanks, Hugh |
03-27-2016, 05:34 PM | #2 |
Re: Mitchell for a mid April build 30 Tudor
why not ask Mitchell for a real answer and not just someone's opinion?
03-27-2016, 05:39 PM | #3 |
1928- 1930 if you have an Oval Speedometer
1930-1931 if you have a Round Speedometer It's the speedometer cable connection. That is the difference and not my opinion :-)) |
03-27-2016, 06:18 PM | #4 |
Thanks Joop. Looking at a used one that was for a 31. Just wondering if that was a big issue. I'd say not!!
03-28-2016, 06:32 AM | #5 |
Mitchell provides speedo cable extension with each O/D. That extension is what has either a "key drive" or "square drive" and that is the difference.
03-28-2016, 12:31 PM | #6 |
They also produce an overdrive to fit the cars with a dropped floor pan, Victoria, A-400, and 31 two door phaeton. The overdrives for these cars have the gear box housing positioned 4.5 inches more forward on the drive train. This also requires a longer stub shaft. The top back edge of the gear box housing is also shaved at an angle. Tom Endy |
