10-19-2015, 04:40 PM | #1 |
Wonder what this is?
10-19-2015, 05:20 PM | #2 |
Re: Wonder what this is?
1950's Borg Warner overdrive from the back of a transmission transplanted into a torque tube. Flange indicates that it is most likely Model A, possibly 1932 Ford. Total length of the 2 pieces would tell which.
The general type of the overdrive was used by nearly all US car makers at one time or another. |
10-19-2015, 07:34 PM | #3 |
I've been researching OD's and stumbled across the add. To bad something like the Ruckstell isn't still available. Looks like the Mitchell is probably my best option. Still a lot of work to install.
Hugh |
10-19-2015, 09:37 PM | #4 |
You can't go wrong with the Mitchell. |
