10-14-2021, 09:21 AM | #41 |
Re: Kit for mating juice brakes to early spindles-Richard's Early V8 garage?
Is the Early V8 Garage still in business?? I have not had contact since July when Richard said he would get back to me on a brake line set up. I have been trying to reach him by phone and email. No response?? Thanks
A man should do what he thinks best! "The Duke" |
10-14-2021, 11:41 AM | #42 |
I'm helping a friend build his 32 Roadster and he ordered a set of the adapter plates from Richard about a month ago - and I tacked them onto his 40 backing plates. I'm sure Richard is still in business - he just tends to be very busy and isn't great about returning calls. I'd just try him again . . .
10-15-2021, 06:22 AM | #43 |
I have a set of 4 1940 backing plates with shoes, painted black, excellent shape, has plates welded on front for 32 spindles. 350.00.
10-15-2021, 08:38 AM | #44 |
Hi Tim
Here is one solution. I have a set of 39-41 backing plates re-drilled for '32 spindles. Shown in the photos are a rear backing plate mounted on a '32 spindle, the '32-34 spindle, and the backing plate complete w/hardware & shoes. |
10-15-2021, 08:52 AM | #45 |
10-15-2021, 09:01 AM | #46 |
I used one of Richard's kits and all went together very nicely. One tip, if you're particular, you should use the '32 style round grease shields vs. the '40 "square" style. I didn't realize they were different hole spacing (duh, makes sense now) until mounting them. |
10-15-2021, 09:40 AM | #47 |
A small indentation along the top of the round shields gives enough clearance for the springs.
10-15-2021, 10:30 AM | #48 |
I welded a piece of 1/4" square stock around the 32-34 spindle, then welded the holes all shut, and drilled to match the later backing plates. A little work with a flap disc and you cant see it was done.
10-15-2021, 10:31 AM | #49 |
I question whether grease shields are even necessary these days? You don't have them on almost any modern drum brake and the quality of the lip seals are very good. I don't believe there is any issue - in NOT using them at all.
03-17-2022, 12:26 AM | #50 |
I sell these laser cut weld on rings, weld the holes shut and redrill using '40 backing plate as template, two weld on rings, two centric rings $85 shipped in states.
03-17-2022, 03:16 AM | #51 |
^^ neat job.
