07-31-2016, 09:06 AM | #1 |
Water pump mystery
This pump was in a running chassis I bought this spring. The seal looks like the one in my pool pump. It wasn't leaking in the short time I ran the engine. It was squealing but a little grease stopped that. I don't see anything like this on the WWW. Not sure what to do with it. I need a good pump for my current engine project.
Hugh |
07-31-2016, 10:40 AM | #2 |
Re: Water pump mystery
Just purchase a rebuild kit and rebuild it. Simple and you'll end up with a pump that is reliable.
07-31-2016, 02:56 PM | #3 |
Sounds like some MAD INVENTOR was at work. "Maybe" he was a pool man??
Bill W.
07-31-2016, 03:26 PM | #4 |
The guy might have been fixing some other problem with all of that stuff. You might want to find another pump and rebuild it.
07-31-2016, 07:49 PM | #5 |
The fan looks like it may be an original 2 blade. If so, replace it with an aluminum pepo before it brakes and distroies your radiator.
07-31-2016, 10:42 PM | #6 |
