Old 10-31-2012, 12:08 AM   #1
JMKnight
JMKnight's Avatar
Default Starting the starter
I came in from the garage after working over five flathead starter motors and could not get one to spin. I tried every trick I know of. Stuff that always worked before. It's going to kill me if I have to take one of them to a rebuild shop!
JMKnight is offline   Reply With Quote
Old 10-31-2012, 12:15 AM   #2
Old Henry
Old Henry's Avatar
Default Re: Starting the starter
So? What did you do to try to get them started? Give us the list so we can see if we think there's anything you missed. All of my starter problems have been worn out brushes. Replaced them and away they went.
Old 10-31-2012, 01:05 AM   #3
JMKnight
JMKnight's Avatar
I was just venting but since you asked, I used some emery cloth to clean the shiny parts, repaired insulation on field coils where needed. New brushes installed and I greased the rotor end. What did I miss and how do I check for shorts?
Old 10-31-2012, 03:33 AM   #4
thirt4
thirt4's Avatar
Is this where a "growler" comes in?
thirt4 is offline   Reply With Quote
