04-01-2021, 08:42 AM | #1 |
Removing Steering Box in an open car
I have a 29 Phaeton and I need to remove the steering box. After looking at it I think I may be able to pull it out from inside the car without removing the brake and clutch pedal. I can see how this would not be possible with a closed car but can it be done in an open car with the top down?
Thanks Ron |
04-01-2021, 08:47 AM | #2 |
Re: Removing Steering Box in an open car
On my '31 roadster I found I still had to remove the pedals...
Tom |
04-01-2021, 08:50 AM | #3 |
I remember it not being very hard to remove the pedals, and it also gives you the opportunity to calibrate the position of both when you put them back on.
04-01-2021, 10:45 AM | #4 |
Check your "Private Messages", Ron.
Marshall |
04-01-2021, 10:52 AM | #5 |
Kevin |
Thread Tools | |
Display Modes | |
