05-28-2017, 09:47 PM | #21 |
Re: GL-5 no no
How about this : http://www.autozone.com/greases-and-...oz-/693859_0_0
05-28-2017, 10:21 PM | #22 | |
Re: GL-5 no no
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 05-28-2017 at 10:55 PM. |
05-29-2017, 07:38 AM | #23 |
Re: GL-5 no no
The Rural King 90wt says specifically for older vehicles with manual transmissions.
05-29-2017, 08:45 AM | #24 |
Re: GL-5 no no
Lucas SAE 85W-140 gear oil
Standards: Exceeds All GL Classifications, API GL-4, API GL-5, API MT-1, SAE J2360 MIL-PRF-2105E, MACK GO-J, PG-2 Limited Slip I wouldn't use it, but it is your decision! |
05-29-2017, 09:00 AM | #25 | |
Re: GL-5 no no
"GL-5 is not necessarily backward-compatible in synchro-mesh transmissions which are designed for a GL-4 oil: GL-5 has a lower coefficient of friction due to the higher concentration of EP additives over GL-4, and thus synchros can not engage as effectively. Also, transmissions which explicitly call for GL-4 oil may have been designed around this lower concentration of EP additives and thus may contain yellow metal parts which GL-5 will corrode." "Gearbox oils are classified by the American Petroleum Institute using GL ratings. The higher GL-rating the more pressure can be sustained without any metal-to-metal contact taking place between transmission components. Separate differential usually have higher pressure between metal parts than gearboxes and therefore need higher GL-rating. For example, most modern gearboxes require a GL-4 oil, and separate differentials (where fitted) require a GL-5 oil." "API Category GL-5 designates the type of service characteristic of gears, particularly hypoids in automotive axles under high-speed and/or low-speed, high-torque conditions. Lubricants qualified under U.S. Military specification MIL-L-2105D (formerly MIL-L-2015C), MIL-PRF-2105E and SAE J2360 satisfy the requirements of the API GL-5 service designation." Last edited by JSeery; 05-29-2017 at 09:09 AM. |
05-29-2017, 11:16 AM | #26 |
Re: GL-5 no no
(GL-5). I don't get what you mean by this....Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
05-29-2017, 02:45 PM | #27 |
Re: GL-5 no no
That is the term gear lube suppliers use. It means a lubracation specified GL-5 meets or exceeds GL-4 specifications. This is confusing because just because it meets and exceeds lubracation requirements does not mean it is safe for "yellow" metals. At one time in the past GL-4 was specified for rear axles for example. When GL-5 became available it was listed as also acceptable to use in rear axles originally specifying GL-4 (backward compatible). BUT, this applies ONLY to it's lubracation qualities, NOT to compatibility with 'yellow' metal (synros, bushings, etc.)
05-29-2017, 03:10 PM | #28 |
Re: GL-5 no no
I was looking at a local auto parts house for GL-4. The parts person said that GL-5 was ok to use in my synchro tranny. I showed him on one of his GL-5 bottles it said and I quote " Not for use in synchromesh transmissions". He said oh I didn't know that. Pretty clear to me....................
05-29-2017, 03:17 PM | #29 | |
Re: GL-5 no no
05-29-2017, 03:52 PM | #30 | |
Re: GL-5 no no
05-29-2017, 04:00 PM | #31 |
Re: GL-5 no no
I was just curious . I've got some Sta-Lube GL-4 140wt. that I will use .
05-29-2017, 04:19 PM | #32 | |
Re: GL-5 no no
05-30-2017, 12:41 AM | #33 | |
Re: GL-5 no no
As stated above-- so over time it peels off the surface one layer at a time. So what is the definition of over time? 1 year 10 years 100 years? Has anyone had a failure of their synchro rings using GL-5 that says it's safe for yellow metals? I have been using it for about 3 years so far with a transmission that has a little over 50,000 miles on it and it made shifting easier and the transmission quieter after the change.
Chisel Evil Lurks...for those that don't carry a side arm!!! |
05-30-2017, 12:34 PM | #34 |
Re: GL-5 no no
It depends on the pressure on the part and the number of cycles. If you like the GL-5 use it, the information is for the folks who care about these issues. No matter what the topic is someone has always been doing it for 50 years with no problem. Just seems to be the way it is. You would think the transmission manufactures telling you not to use it would be enough.
An added note: There are some newer GL-5 lubes that claim to be safe. It is not the GL-5 rating that is the issue, it is the EP additive. If some suppliers are using different additives that would make a difference. Last edited by JSeery; 05-30-2017 at 01:41 PM. |
05-30-2017, 04:45 PM | #35 |
Re: GL-5 no no
Old Henry,
Have you asked Mac VanPelt what he recommends using in his rebuilt transmission? I think he would be the definitive source on this information. |
05-30-2017, 04:57 PM | #36 |
Re: GL-5 no no
I didn't ask him, neither did he volunteer a recommendation. Neither did he say there was any excessive wear on any of my "yellow metal" since I replaced them two years and 33,000 miles ago. I've had my transmission opened up for rebuild/inspection 4 times in the last 10 years, 100,000 miles, and have never seen any excessive wear of "yellow metal". That's using GL-5 lubricant. So, although the theory of GL-5 causing excessive wear of "yellow metal" parts probably makes sense, in actual practice I doubt it's enough for anyone to actually notice, especially anyone just driving their cars a few miles a year. Even so, since I'm driving mine 10,000 miles a year, I'm doing anything and everything anyone suggests to make my transmission last longer. May not make a difference but, then, again, maybe it will. It's worth the effort "just in case."
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 05-30-2017 at 05:59 PM. |
05-30-2017, 07:59 PM | #37 |
Re: GL-5 no no
Old Henry, I was re-reading your previous post regarding Mac's rebuild and how happy you are with the service. I came to a post by a Pete VS who said he purchased some tranny parts from Mac and had him send him some transmission oil. Mac sent him GL-4. After reading this I will be changing my transmission from GL-5 MT to GL-4.
05-30-2017, 08:45 PM | #38 |
Re: GL-5 no no
I have been reading this with interest. I just last week put GL4 85-90 in my T9 or is it T8 four speed. I would have liked to use a heavier GL4 like 140w, but napa didn't have it on the shelf. While not a synchro, does the crashbox have yellow metal?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
05-30-2017, 11:09 PM | #39 |
Re: GL-5 no no
on any newer vehicles we work on we try to use what the manufacturer recommends but on older cars we use GL-5 in pretty much everthinghave never had a problem that i know of in 40 years.im sure there is valitity in the debate but i think its overblown.a race car or the like maybe but i dont think its a big deal on an old thre or four speed.this is a general statement.i dont worry about it much
05-31-2017, 08:48 AM | #40 |
Re: GL-5 no no
This discussion has been valuable. While some posters view the information being conveyed as redundant "old news", i am thrilled to get new professional opinion and amateur perspective, alike.
I have worked in the advertising field for the past forty years. The original post and the discussion which has followed reminds me of timeless training in my career: The first time people look at any given ad, they don't even see it. The seventh time, they see the message they start to get a little irritated with it. By the seventeenth time of seeing that lousy ad, they make a note to buy the product. By the twentieth time a prospect sees the ad, they go buy the product that will solve their need. With this in mind, thanks for reopening good discussion on this age-old topic. And for sharing your individual thoughts. It is clear that many people, even veterans in this stupid hobby, are in some cases just getting exposed to this perplexing oil dilemma. I'm especially pleased that the original post didn't get taken down as quickly as it went up. |
