05-16-2017, 02:42 PM | #21 | |
Re: How to remove pilot bearing? '47 59A engine
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
05-16-2017, 02:43 PM | #22 |
My son used pieces of wheat bread. I told him he was crazy, but it worked! The auto parts stores didn't have the right sized puller
05-17-2017, 12:11 AM | #23 |
I had the same issue on an off topic engine. Puller wouldn't fit, but did the grease trick. Next time I had to do it, I did bread because it sounded so weird, I had to try it. Sure enough, worked like a charm, and was much easier to clean up then the grease.
05-17-2017, 01:17 AM | #24 | |
05-17-2017, 01:24 AM | #25 |
Henry,NO one has mentioned the crap chin**se bearing that comes with the kit,do your self a favour and drop into your local bearing supply shop and get an SKF or US made one.
Lawrie |
05-17-2017, 08:12 AM | #26 |
