Go Back   The Ford Barn > The Swap Meet > For Sale > Model-A
Old 04-20-2012, 07:48 AM   #1
Dan Baron
Dan Baron's Avatar
Default 1930 Deluxe Coupe
City: Seekonk
State: Mass
Price: $12,000
Up for sale now, is my 1930 Deluxe Coupe. Engine was rebuilt many years ago but never driven, so it realy only has a couple of years on a new build. Some of the things that have been done so far are:
1-Replaced both sets of bumpers
2-Flushed radiator
3-Installed newer hoses
4-Replaced carberator
5-Rebuilt distributor
6-Replaced intake manifold
7-Replaced exhaust manifold
8-Installed an aftermarket horn
9-Installed boots on shift and brake levers
10-Detailed engine compartment (cleaned and painted)
11-Fabricated side panels in rumble area
12-Replaced rear view mirror
13-Installed side view mirrors
14-Repaired seat adjuster
15-Installed new battery
16-Installed new pads on brake and clutch pedels
17-Installed older hub caps on all wheels
18-Replaced spark and throttle rods
19-Installed new leekless water pump
20-Replaced two blade fan
21-Replaced spark plugs and wires with better used ones
22-Replaced vacuum wiper and blade
23-Replaced gas line to carberator
24-Replaced muffler with a newer used one
25-Replaced gas cap
26-Replaced gaskets in gas guage
27-Replaced ignition switch
28-Replaced floor mat
29-Replaced choke rod
These's are just a partial list of the things I've done to this coupe.
Things that I would like to get done to make this an awsome ride?
1-Repaint entire car (as it still looks great from 10 feet, but up close not so good.) I prefer it to look as good as my Town Sedan. (Also for sale by the way.)
2-Replace right front fender (It had been repaired with a piece of sheet metal riveted to the underside.) Better to replace than repair this fender.
3-Replace radiator shell (It has a small dent in it that bothers me.) Hardly noticable.
4-Replace radiator cap
5-Something in the front end needs to be look at, as it tends to shake a
little. (I'll be playing with this in the comming week or so.)
6-Interior is all original and in great shape, but some people would want to
replace it. (I don't think I would replace it as it is in such original
condition, and still looks great.
7-Remove a dash lite that I don't think belongs. It' on the pasenger side of
the dash.
This Coupe has had body work done by an amature and does have bondo here and there, but it looks pretty good. A fresh coat of paint would do wonders for this car, and it is very presentable as it is. So you are able to use and enjoy my coupe as you are restoring it.
This Coupe runs great, steers great, stops great. I can also e-mail better pictures upon request, for those of you who are truly interested in it. Please call my cell at 774-991-0559 if you have any questions at all. Or e-mail me at [email protected]
All I want, is a little bit more, than I'm ever going to get!
Dan Baron is offline   Reply With Quote
