Old 06-15-2011, 03:41 PM   #1
Dan Baron
Dan Baron's Avatar
Default Off by 3/4 of an inch.
I just switched out my front end from my 30 town sedan with that of a 30 coupe. the front end fit perfictly on the coupe but the brake lines for the town sedan were 3/4 of an inch too short. should I just ajust the brake lines or is there something else I should do?
All I want, is a little bit more, than I'm ever going to get!
Dan Baron is offline   Reply With Quote
Old 06-15-2011, 04:15 PM   #2
hardtimes
hardtimes's Avatar
Default Re: Off by 3/4 of an inch.
Dan,
With what you've given here...I'd start with adjusting! If that isn't satisfactory, pull the front drums and check it out.
Old 06-15-2011, 04:24 PM   #3
Dan Baron
Dan Baron's Avatar
I pulled the whole front ends I didn't do anything with the drums or hubs. Shouldn't they line up? Why did the coupe fit and not the town sedan?
Old 06-15-2011, 04:27 PM   #4
ford1
did you pull the brake adjusting arm back with your hand to take up the slack in the brake arm?
ford1 is offline   Reply With Quote
Old 06-15-2011, 04:29 PM   #5
Dan Baron
Dan Baron's Avatar
Yes, I did pull them back as far as they would go. I even tried to force them back. They are as far back as they can go.
Old 06-15-2011, 05:34 PM   #6
ford1
did you take all the slack out of the rear brake rods to the brake cross shaft?
Old 06-15-2011, 05:39 PM   #7
Bob C
Are the levers at the same angle on both axles?
Bob C is online now   Reply With Quote
Old 06-15-2011, 05:45 PM   #8
Dan Baron
Dan Baron's Avatar
What I didn't do was step on the brakes to bring the rods foward. Maybe I'll try that.
Old 06-15-2011, 05:55 PM   #9
Dan Baron
Dan Baron's Avatar
Well that didn.t work. I adjusted the rods and they seem just right now. They are tight, and it stops good. Just think that it was strange that I'd be off by that much.
