Old 07-12-2017, 08:20 AM   #21
Johnnydidd
Johnnydidd's Avatar
Default Re: Hot tip from a cool guy.
By the way when can we expect to hear about your next trip?
Johnnydidd is offline   Reply With Quote
Old 07-12-2017, 10:09 PM   #22
1931flathead
I just went on you tube he has 5 new ones on there
1931flathead is offline   Reply With Quote
Old 07-13-2017, 05:42 AM   #23
fortyonerag
fortyonerag's Avatar
Originally Posted by V8COOPMAN View Post
Craig.......After a long career dealing mostly with the power distribution and UPS systems powering a huge air traffic control facility, I thought I understood a little bit about electricity, along with some reasonably-effective troubleshooting techniques to use when problems arose. I'll be darned, but your single paragraph above makes me realize just how dumb I must be with electrical stuff. I honestly never knew that 6v stuff only heats-up enough to make it easy to find the warm spots during a short.
One little tip here for ya none-the-less......there are SHORTS, and then there are the type of SHORTS that you haven't experienced....yet! DD
Reminds me of my time working on 480VDC UPS systems at YMML.
Good advice. A proper short can ruin your entire day
fortyonerag is offline   Reply With Quote
Old 07-13-2017, 08:53 AM   #24
cmbrucew
cmbrucew's Avatar
Traction motors and generators for locomotives use 600 VDC. You can have both positive and negative shorts to frame/ chassis.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 07-13-2017, 11:40 AM   #25
Old Henry
Old Henry's Avatar
I'm still editing videos. Then I'll write it all up. It was a great trip up the west coast from San Francisco to the Olympic Peninsula. Yesterday I got back from a three day trip to Yellowstone with a couple of grandsons camping in the woods. Good time had by all.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 07-13-2017, 11:57 AM   #26
V8COOPMAN
V8COOPMAN's Avatar
Ours were 480VAC-in, then to 432VDC, and back to 208VAC-out! What is YMML? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-13-2017, 12:18 PM   #27
Lawson Cox
Lawson Cox's Avatar
Originally Posted by tubman View Post
Speaking of heat shrink tubing, I find I use it a lot. (One of those things that may effect a "repair vs. replace" decision.) The problem with it is that it can be tough to get installed. A friend of mine in the electronics business put me onto some specialized heat shrink tube that shrinks at a 3 to 1 ration, which is significantly more than the stuff you can get from the hardware store. (It's helped out a lot in some situations, but it is kinda expensive.) Also when working with heat shrink, it's best to have a heat gun; I've seen it done with a Bic lighter, but I never have any luck with stuff like that.
Speaking of heat shrink tubing, just how much voltage/amps/whatever will that stuff insulate against ? As you are my knowledge of and ability to discuss electricity intelligently really sucks. Lawson
Old 07-13-2017, 08:52 PM   #28
fortyonerag
YMML = Melbourne Tullamarine Airport here in Australia
