Old 12-02-2013, 03:43 PM   #1
Ford1931
Ford1931's Avatar
Default Shift Knob Rusted On Shifter
I have a very nice early mushroom style shift knob that is rusted to the shift tower. I have turned it upside down in a vise and have been soaking it often with the acetone, transmission fluid 50 50 mix. I even tried heating the shift tower. I have tried turning it with a band clamp wrench. I am trying to be careful as I do not want to break the knob. Anyone found anything else to work? As a last resort, I could probably cut the tower drill and re tap it.
Ford1931 is offline   Reply With Quote
Old 12-02-2013, 03:59 PM   #2
hardtimes
hardtimes's Avatar
Default Re: Shift Knob Rusted On Shifter
Just went thru same situation recently. Soaked the knob repeatedly and let it sit in sunny socal sun. Twisted back/forth , by hand, nothing for long time...then started to move. Soaked then for another month, then just when I was about to use 'bigger hammer' , it gave in/came loose. Beautiful onyx (?) with solid threaded brass base. Figured someone would appreciate it..if I could/would get it off. Ha, set it aside and forgot about it..till you came along,eh ! NEVER GIVE UP !!
hardtimes is offline   Reply With Quote
Old 12-02-2013, 04:38 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
About 5 years ago I had the same thing with a mushroom knob. Strap wrench wouldn't budge it, so I sprayed some Gibbs on it and set it aside. A week later I unscrewed it with my hand. I still can't believe it worked so well. Nothing before or after has had such a complete turn around like that. Gibbs and Kroil always help. but it's usually still quite a fight.
Old 12-02-2013, 04:46 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Meybe sumone loosened it fer you whin u were'nt lookin'---HA HA HA HA HA---Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 12-03-2013, 12:57 PM   #5
28ACoupe
28ACoupe's Avatar
PB Blast also works well for projects like this.
Don't use WD-40, especially if you live anywhere near either an ocean or where they salt the roads or you will make it worse.
1928 Model A Business Coupe
Rebuild picture gallery here
The light at the end of the tunnel has been turned off due to budget cuts.
28ACoupe is offline   Reply With Quote
Old 12-03-2013, 01:05 PM   #6
Russ/40
Russ/40's Avatar
I'm really puzzled by your comment. How does Wd40 make it worse? No sarcasm here, I'm really curious.
Russ/40 is offline   Reply With Quote
Old 12-03-2013, 01:16 PM   #7
BCCHOPIT
BCCHOPIT's Avatar
X2 on that one...
But I think I would use just a little Sarcasm :-))
So yes please tell us more
WAC that banger in the A$$ and drive it home hard
http://waccustoms.com
BCCHOPIT is offline   Reply With Quote
Old 12-03-2013, 01:56 PM   #8
mot
Registered User
mot's Avatar
try soaking wd 40 on some pot metal.like a door cylinder or pop out
it will destroy it
i threw out all my wd 40
its for water displacement
i know some have good results with it,but after ruining a perfectly good pop out and door cylinder
no thanks
mot is offline   Reply With Quote
Old 12-03-2013, 04:12 PM   #9
mass A man
mass A man's Avatar
If you like your shiftknob, you can keep your shiftknob, but don't let this happen to you.
mass A man is offline   Reply With Quote
Old 12-03-2013, 04:49 PM   #10
smurph
smurph's Avatar
Try the Kroil. The stuff works like magic! Let it soak in for a while and repeat the process if necessary. Might do it for you.
smurph is offline   Reply With Quote
Old 12-03-2013, 04:53 PM   #11
Russ/40
Russ/40's Avatar
it will destroy it
no thanks
How does it destroy it. Dissolve the metal or ???????? Explain, and over what length of time was necessary to cause this??
Old 12-03-2013, 06:06 PM   #12
Tom Wesenberg
From what I've heard it can make the potmetal swell. I had some bolts in a plastic container, and after I sprayed some WD-40 on them to prevent rust, the plastic container warped out of shape so the lid no longer fits.
About 12 years ago I discovered WD-40 makes an excellent remover for price stickers and the goo it leaves behind. It also removes felt tip markers black ink from plastic. I also use it to protect bare metal on modern cars, such as the alternator, tranny, throttle linkage, etc. If I spray these parts about once a year they stay pretty nice looking. Without the spray the road salt mist will do a number on them.
Old 12-03-2013, 10:28 PM   #13
28ACoupe
28ACoupe's Avatar
WD-40 and salty, wet air will actually promote the oxidation of metals of all kinds. I.E. Rust.
Sure, it will break parts free for a while, but then a day or so later, you are back where you started from.
You won't find any old timers down on docks by the ocean with WD-40 anywhere on their boats. They usually use either 3 in 1, Kroil, or PB Blast specifically for this reason.
Old 12-20-2013, 02:10 PM   #14
Ford1931
Ford1931's Avatar
The knob finally came off without breaking. I soaked (submerged) the entire knob in the acetone transmission fluid mix for about a week. I then locked the knob between two, two by four pieces of wood and tightened the vise just enough so the knob would not slip when I put a vise grips on the shift tower. I rocked it back and forth and it finally started to move. I checked to make sure the knob was not getting soft from the solution, but seemed to be fine. Hope this helps someone else with the same problem.
Old 12-20-2013, 03:07 PM   #15
28ACoupe
28ACoupe's Avatar
Good job!
Be sure to clean up the threads before you put it back together.
