Old 12-02-2013, 10:25 AM   #1
old46ford
Default Rear hub/drum seperation
I need to replace a pitted hub in the rear. How do I separate the drum/hub assembly? I would like to reuse the drum and install a new hub. Any advice?
old46ford is offline   Reply With Quote
Old 12-02-2013, 10:25 AM   #2
old46ford
Default Re: Rear hub/drum seperation
It's a 1946 two door coupe. Hubs mount on the inside of the drum.
Old 12-02-2013, 02:30 PM   #3
Charlie Stephens
Post your general location (and put it in your profile) and ask for recommendations for a shop with the tools and knowledge about how to do it. It is not something you do at home. A big hammer just results in scrap parts.
Charlie Stephens
Old 12-02-2013, 03:23 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
old46ford...Click on the link below. It'll show the way your drums have been attached to your hubs at the factory, and WHY you cannot simply press or hammer the lug bolts out. In the lower portion, a tool is shown that can be used to cut the swedge on the lug bolts. Available at Snyder's Model A among others. DD
http://www.fordgarage.com/pages/swaging.htm
Click Links Below __
T5 W/TORQUE TUBE
Old 12-02-2013, 04:20 PM   #5
Karl Wolf
Karl Wolf's Avatar
To re use the drums, drill the old studs from the back. I start with a 5/16" or 3/8" bit to start, easier to pilot. I use 9/16" bit til I'm sure that I'm past the flange that is the back of the stud. Use a punch to push the studs out the front/ outside...
This is because the studs are swaged (riveted) on the outside. If you were scrapping the drums, you could use a swage cutter to cut the end of the stud-and the drum so you you could press the studs in (toward center).
Either way, new studs are in order.
And machining the drum with the new hub.
Karl
Karl Wolf is offline   Reply With Quote
Old 12-02-2013, 04:33 PM   #6
old46ford
I will be using new hubs and drums... any recommendations for sources, other than Macs?
Old 12-02-2013, 10:28 PM   #7
Old Henry
Old Henry's Avatar
Changed your mind since original post asking how to separate the hubs and drums? No need to do that if you're replacing both.
Here they are at C&G: http://cgfordparts.com/ufolder/cgcat...number=opt-2hf
Old 12-03-2013, 12:07 PM   #8
old46ford
The hub is badly pitted from a leaking original seal letting moisture in over the past 50 years or so and the drums have been turned already, so I will fork out the $370 for a new assembly.
Old 12-03-2013, 01:23 PM   #9
BCCHOPIT
BCCHOPIT's Avatar
Find a good used hub and put a new drum on it.
You will save a lot of money.
WAC that banger in the A$$ and drive it home hard
http://waccustoms.com
BCCHOPIT is offline   Reply With Quote
Old 12-03-2013, 01:38 PM   #10
Charlie Stephens
Find a good used drum and hub assembly. Be sure the drum is under 12.060.
Charlie Stephens
Old 12-03-2013, 02:27 PM   #11
Old Henry
Old Henry's Avatar
Here's a complete pair of everything for $100: http://www.ebay.com/itm/1946-1947-19...ccc0e6&vxp=mtr
Old 12-03-2013, 02:54 PM   #12
Dave/Green Bay
old46ford if you pay the shipping I probably have a set of good hubs with drums that are not usable. Let me know Dave/Green Bay
Dave/Green Bay is offline   Reply With Quote
