Old 04-13-2017, 01:35 PM   #1
Milt K from Pa
Milt K from Pa's Avatar
Default 39 Ford gas sender
Barners;
I have a friend that needs to repair his original gas sender for his '39. Since most if not all repops are poor, I know I've seen a post of someone who does rebuilding/repair of these units. Can someone recommend a GOOD craftsman for this???
Thanks for the help.
Milt K from PA
Milt K from Pa is offline   Reply With Quote
Old 04-13-2017, 02:27 PM   #2
JSeery
JSeery's Avatar
Default Re: 39 Ford gas sender
Might try a search, this has been discussed pn numerous threads. I don't remember any of the rebuilders or I'd give you a name.
Old 04-13-2017, 02:31 PM   #3
adileo
adileo's Avatar
When mine wasn't working on my 39, the float was no good. Saturated with gas.
Have you pulled your friends out? That may be the issue.
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 04-13-2017, 07:43 PM   #4
Milt K from Pa
Adileo,
My friend said he had it out and didn't indicate the float was logged, just won't work. I'll try a search as suggest in lieu of any other suggestions.
Thanks all.
Milt K from Pa
Old 04-13-2017, 07:57 PM   #5
JSeery
JSeery's Avatar
Not sure if this helps any, but here is some information on the fuel gauge. 19Forty has posted some of this information in the past.
Old 04-13-2017, 08:14 PM   #6
JSeery
JSeery's Avatar
Here are some links:
https://fordbarn.com/forum/showthread...ht=king+seeley
Old 04-16-2017, 12:27 PM   #7
Clem Clement
Clem Clement's Avatar
I got one off this swap meet page for $15.
Clem Clement is offline   Reply With Quote
