Old 08-18-2014, 12:23 PM   #1
al pa.
Default front e-brake cable
Haven't been able to figure the correct routing of front cable,between the area of master cyl.,and the bracket welded to the torque tube.The cable seems to be too long.should it go thru frame x member,or attach to something with clips?Description would be helpful,Thx.,Al
al pa. is offline   Reply With Quote
Old 08-18-2014, 05:30 PM   #2
alanwoodieman
Default Re: front e-brake cable
year of car could be helpful. it goes thru the x in the frame and is attached to the frame near the brake master cylinder with a bracket
alanwoodieman is offline   Reply With Quote
Old 08-20-2014, 08:43 AM   #3
al pa.
Sorry,47 merc coupe THX.
Old 08-21-2014, 08:36 AM   #4
19Fordy
19Fordy's Avatar
The clamp looks like this. This is from a 40 FORD but I am quite sure it's the same for the Merc. Part #2279 You could make one pretty easily out of sheet metal. I tried to take a photo of it under the car but it's really hard to see with the car on the ground. That pointed inside edge on the sketch should be a radius that matches the outside radius on the bottom of the clamp.
Old 08-21-2014, 08:46 AM   #5
V8COOPMAN
V8COOPMAN's Avatar
Adel clamp should work well. Available many sizes. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-23-2014, 09:17 PM   #6
al pa.
Thanks,guys for the feedback,don't know what I'd do without fordbarn!
