Old 03-19-2024, 05:57 AM   #1
thirty2ragtop
Default 1932 Ford Subrail Frame Extensions
Are the Subrail frame extensions the same for all body styles? More specifically, the 32 coupe, roadster and the 3 window? I know that the 32 3 window was manufactured by Murray, but did they use components from the Ford plant to build the subrail extensions in order to sit-down upon the standard frame?
I'm trying to rebuild a channeled 3 window. Thanks for your response.
thirty2ragtop is offline   Reply With Quote
Old 03-19-2024, 10:12 AM   #2
alchemy
alchemy's Avatar
Default Re: 1932 Ford Subrail Frame Extensions
The 3-window has a different shape back there. I really doubt the rear extensions are the same.
alchemy is offline   Reply With Quote
Old 03-19-2024, 10:59 AM   #3
Karl Wescott
Karl Wescott's Avatar
Just build your floor to support the back panel and corners of the body. Given you are channeling the body IF you had originals or accurate reproductions you would be cutting them up anyway.
Karl Wescott is offline   Reply With Quote
Old 03-19-2024, 06:01 PM   #4
thirty2ragtop
I have an East Coast HEAVY channeled car............trying to UN-CHANNEL it. I also have the Juggars Coupe which is a West Coast channeled 3 window which will remain that way. thank you. bob
Old 03-19-2024, 06:01 PM   #5
thirty2ragtop
Thank you for your comments
Old 03-19-2024, 09:03 PM   #6
John R
Brookville has two different part numbers for subrail extensions, one for their roadster and one for their 3-window coupe. So apparently they differ somehow. The Brookville 3-window one which I have is very similar to the original Ford subrail extension but is somewhat longer. I am repairing a 32 3-window coupe in which the subrail's horizontal flanges which support the floor have been removed. We are traveling a similar road, so PM me if you want to discuss in more detail.
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 03-19-2024, 09:23 PM   #7
DavidG
DavidG's Avatar
Note that Brookwille 3-window bodies do not have the original type floor from below the front seat rearward to the end of the body. Instead they used their already-existing roadster, standard coupe, sport coupe, and cabriolet floor.
Old 03-19-2024, 10:39 PM   #8
thirty2ragtop
Right! Most guys want to get rid of the stock floor in lieu of the roadster floor in order to obtain more room in the chassis area below. I'm just trying to get back to GROUND ZERO on this body........then move forward with the project. Interesting all of the "early" and "late" things that can go on with these bodies. I'm trying to build this as an early body with the oil can recess in the firewall, dog-bone visor brackets, more screws in the garnish moldings, etc.
