Old 06-25-2018, 02:50 PM   #1
iron mountain 1
Default tubes
I was lucky enough to buy a set of new inner tubes (19") that have meatal valve stems. I did not get any hardware with them.
My question is... do I have to use the metal piece that holds the valve stem off of the inside of the rim. It looks like a rectangle piece of metal with a hole in it. I saw this in a picture in the MAC'S parts catalog.
Sorry for the dumb question but have never had metal stem tubes before.
Thanks Kris
iron mountain 1 is offline   Reply With Quote
Old 06-25-2018, 03:38 PM   #2
jwilliams81
jwilliams81's Avatar
Default Re: tubes
Yes, it is assembled like this:
http://www.mtfca.com/discus/messages...tml?1476898025
Even though the above is a model T, it still shows how the piece you are talking about is used.
Here is a video on the Model A:
https://youtu.be/nkNTVBPDO7s?t=2m5s
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 06-25-2018, 05:08 PM   #3
midgetracer
midgetracer's Avatar
Default Re: tubes
Yes you need rim washers.
midgetracer is offline   Reply With Quote
Old 06-25-2018, 07:30 PM   #4
iron mountain 1
Default Re: tubes
Thank you for the replies. Just ordered from Mac's and holy cow!!! do they charge for shipping.
Old 06-26-2018, 12:15 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: tubes
Most guys like Bert's, Bratton's and Snyder's the best.
Old 06-26-2018, 10:15 AM   #6
Bob C
Default Re: tubes
Mac's is the last place I would order from.
Bratton's has them. https://www.brattons.com/30-31-bridge-washer.html
Old 06-26-2018, 05:36 PM   #7
marty in Ohio
marty in Ohio's Avatar
Default Re: tubes
If you ever get them from Mac's, they probably won't fit.
marty in Ohio is offline   Reply With Quote
