Old 02-20-2017, 03:50 PM   #1
al pa.
Default 1947 merc coupe
City: near pgh.
State: pa.
Price: 6800 obo
Flathead,probably not original engine.front distributor,water outlets in center of heads.car driven into garage,cannot start indoors due to fuel system work,car is on stands,and cannot get outside without dollys to get around corner.
Rebuilt-carb,gas tank cleaned and sealed,steering wheel refinished,bumpers rechromed,grille surround rechromed,camaro calipers in front.
New-tie rod,front axle,wishbone and ball,front spring,front disc brake kit,front tube shock kit(not installed),wire harness(mostly unfinished)front disc brake pads,rear wheel cylinders(one spare),dual master cyl.corvette style iron,master cyl.remote fill kit,rear shock dogbones(not installed),dummy spotlights,repop gravel shield(rear bumper to body),gas line tubing(plated needs installed),gas cap,hose to connect tank to filler tube,front wheel bearings,extra wiper blades and arms,reds headers nickel plated,fanbelt,wide belt pulley on alternator,front and rear emergency brake cables,four new tires,wheels sandblasted and epoxy primed,rear 15" f150 wheels,front 14"s10 wheels,adjustable proportioning valve,residual pressure valves,2 glasspack mufflers.
Needs-interior,clean and paint underside of front clip,door weatherstrip,elec.fuel pump and filter reinstalled,(momentary switch to prime carb is under dash),rear fuel line installed(tank to elec.pump),battery,front shock kit installed,horn hookup.
Notes-paint is corvette yellow with lincoln metallic green scallops painted by previous owner and skirts to match.
extra set of sandblasted tail light housings no lenses or bulb sockets.
Includes new adjustable low pressure electric fuel pump(never used),new repop mechanical fuel pump(never used)
Voltage reducer for stock gages 12v.to 6v.under dash.
Drivers side exhaust has been run under frame to avoid master cyl.and brake lines
Includes spare upper and lower radiator hoses.
New repop dash knobs(maybe 1937?).
New repop ford fan shroud(won't work for merc).
1970? buick park avenue bucket seats.
New Winfield tool works drum puller(cost about $120.00)
Reproduction dash trim-never used-has merc radio grille not ford grille normally used now.Very hard to find,cost $600.00 years ago.
New flex fuel hose(to fuel pump)
2 56/57 cadillac hubcaps with new center bullets.
Body to frame cushion pads-not used-with bolts.
Have bumper jack.
Gear oil for fan.
Odd hardware-mixed-from former owner.
New rear motor mount(rear of trans.)
Need price suggestions,garage is congested,only one person at a time inside,take your best shot,no negotiations.
al pa. is offline   Reply With Quote
Old 03-10-2017, 02:45 PM   #2
al pa.
Default Re: 1947 merc coupe
47 merc coupe [email protected]
Old 03-29-2017, 07:54 AM   #3
al pa.
After seeing prices for other comparable cars,and comments that it must be a scam at the price listed,the price is no longer valid,and will be higher at about $8000.00.
Old 03-29-2018, 03:01 PM   #4
al pa.
replacement e-mail address,for cancelled verizon address,is now [email protected] ,for inquiries on the 47 merc coupe,sorry for the inconvenience.
