Old 10-20-2017, 12:38 PM   #1
adavis
adavis's Avatar
Default Grease for window regulators??
I'm installing the new glass in my 1940 Tudor and would like to apply a fresh dab of grease to the regulators and tracks. I have always wondered what the "dry" grease is that manufacturers apply to parts like this. It doesn't smell, doesn't melt in the heat, and maintains consistency for decades. There is still some remaining on my regulators and I'm confident they haven't been touched since the car rolled out of the factory in 40. Any thoughts on what type of product I should use?
I will try silicone spray for the glass channels.....I'm curious about what to use on the regulators and tracks.
Thanks.
adavis is offline   Reply With Quote
Old 10-20-2017, 12:58 PM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Grease for window regulators??
White lithium grease.
Old 10-20-2017, 01:06 PM   #3
rotorwrench
rotorwrench's Avatar
They may have used a graphite lube like slip plate. It's still available but you might have to search a bit for it. Modern greases last very well but they do tend to attract dust particles over time. They may be a better corrosion inhibitor but it depends on the area conditions whether that would be a problem or not.
Old 10-20-2017, 01:09 PM   #4
adavis
adavis's Avatar
Isn't that the same as LubriPlate, the stuff you use to rebuild an engine? If so, the stuff I've used is pretty thin and would fall right off the regulator and end up in the bottom of the door/quarter. Is there a type of white lithium grease that is firm/dry?
Old 10-20-2017, 02:14 PM   #5
Brian
Brian's Avatar
Possibly consider using an aerosol chain lube
Old 10-20-2017, 02:25 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
All I can remember using on the few that I lubricated over the years was plain old fashioned 'wheel bearing grease', the kind that was 'stringy' and stuck to everything. (Probably the same stuff Henry used)
Like they say "this ain't rocket science"
Old 10-20-2017, 02:51 PM   #7
rotorwrench
No, Slip PLate is a dry graphite lube. https://www.slipplate.com/
It's available in regular cans or rattle spray cans. There are also moly type lubes that are paste and spray as well under other brand names.
Old 10-20-2017, 04:55 PM   #8
Fibber Mcgee
Fibber Mcgee's Avatar
I used lubriplate(probably as old as the car) it's thicker than wheel bearing grease and sticks well to the metal.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 10-20-2017, 09:42 PM   #9
51 MERC-CT
51 MERC-CT's Avatar
Look for a can of this.
Old 10-20-2017, 10:23 PM   #10
RalphM
RalphM's Avatar
That's the right stuff!
RalphM is offline   Reply With Quote
Old 10-21-2017, 09:39 AM   #11
rotorwrench
This might be easier to find.
https://www.walmart.com/ip/3-IN-ONE-...&wl13=&veh=sem
Old 10-21-2017, 10:24 AM   #12
51 MERC-CT
51 MERC-CT's Avatar
Originally Posted by rotorwrench View Post
If you use that stuff on the window regulators,the vehicle warranty will be voided
Old 10-22-2017, 06:33 PM   #13
adavis
adavis's Avatar
I stopped by the oldest auto parts store I have locally and explained my situation. They knew exactly what I was referring to and handed me a tube of Sil-Glyde and from the looks of it I think they're right. It has been around since the 50's and if the description on the tube is accurate it is exactly what I need. Thanks for the advice everyone.
Sent from my SM-G930P using Tapatalk
