Old 04-01-2020, 07:05 AM   #21
tinkirk
tinkirk's Avatar
Default Re: Cam spring and button
check crank end play, make sure crank is not moving for and aft
reset timing to make sure that is not it, with a light if possible
tinkirk is offline   Reply With Quote
Old 04-01-2020, 11:58 AM   #22
Phil Brown
Phil Brown's Avatar
Light pressure on the clutch pedal with the engine running will stop the crankshaft from moving back and forth if thats whats making noise it should stop or at least change in tone
Phil Brown is offline   Reply With Quote
