Old 07-24-2022, 12:07 PM   #1
marc silva
marc silva's Avatar
Default Rear spring replacement
I am about to put a new rear spring in and I have always disconnected everything because I was removing the complete rearend. This time I just want to change the spring so if I remove the wheels and disconnect the shock links will the rearend drop down enough with the brake rods still attached to sneak out the spring? I know if I try this I will have to unbolt the anti-rattlers as well. Just wondering. The brake clevises are a bit of a pain in the butt. Thanks for your opinions, Marc
marc silva is offline   Reply With Quote
Old 07-24-2022, 12:15 PM   #2
old ugly
old ugly's Avatar
Default Re: Rear spring replacement
no the brake rods will have to be undone at the axle end. and the antirattlers unbolted as well.
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
Old 07-24-2022, 02:17 PM   #3
Herb Concord Ca
You still need a spring spreader to remove the shackles.
Herb Concord Ca is offline   Reply With Quote
Old 07-24-2022, 02:29 PM   #4
marc silva
marc silva's Avatar
I have a spreader I got that covered. Thanks
Old 07-24-2022, 02:30 PM   #5
Tom Endy
Tom Endy's Avatar
The rear spring on a Model A can be lethal. Approach it cautiously.
Tom Endy
http://www.santaanitaas.org/wp-conte...ear-spring.pdf
