02-14-2021, 05:27 PM | #1 |
Shock ID
Going through boxes of used model A parts in someones garage I came across these. Complete set of 4. They were very dirty and oil stained so I assumed they were good for possible rebuild. Got home and cleaned them up and found they are like new. Either NOS or rebuilt. My car is not a show car and will never be one but is my almost daily driver weather permitting. In the book of judging I could find no reference to these markings. Can anyone shed light on this?
02-14-2021, 05:41 PM | #2 |
Re: Shock ID
Well it’s not a 31
With the script and non-indented cover its likely 28-early 29 Don’t think it’s a “Pete” reproduction Pull the filler plug and see what might pour out Is the shaft free? If you loosen the adjustment (counter clockwise I think) does the shaft turn in both directions; tighten down does it lock in one direction? As they say “after further review” I looked it up and those are Pete shocks They say Chicago instead of Buffalo. They did not have a good service record Last edited by Oldbluoval; 02-14-2021 at 08:37 PM. |
02-14-2021, 07:02 PM | #3 |
Re: Shock ID
What you have is a set of reproduction shocks. Since you have no interest in showing your car, they should work for you.
02-14-2021, 07:07 PM | #4 |
Re: Shock ID
Ordsgt
I think these were a aftermarket shock produced in the 70's I believe? I've seen them before and have some literature on them that I can't put my finger on at the moment. I think they have been mentioned on the FB in the past. They look official |
02-14-2021, 08:54 PM | #5 |
Re: Shock ID
Found a post on this forum from 1981 about these shocks. Also in the posts that followed was a copy of the add for the shocks. They were made By Antique Auto @ Parts by Pete. Also known as Peter Buciak"Vendor". A set of 4 with arms, links and hardware was $210. There were reports that they were junk and also some who stated they were good and lasted for years. As I paid $50 for the box I guess I didn't get stung too bad. They are unused and all seem to work. May try them out come spring. Thanks for your replies. Next time I will check the forums for info before posting
02-15-2021, 12:59 PM | #6 |
Re: Shock ID
Don |
