01-03-2024, 10:14 PM | #1 |
Buick drum instalation
Hi just to make sure
to instal buick front drum on a 40 ford we need 46-47-48 hubs ? |
01-04-2024, 12:34 PM | #2 | |
Re: Buick drum instalation
https://www.peteandjakes.com/parts/p...earings-seals/ |
01-04-2024, 01:20 PM | #3 | |
https://www.jalopyjournal.com/forum/.../#post-5303550 Coop |
01-05-2024, 09:59 PM | #4 |
thanks nice work
but im looking for info if i use stock ford spindle |
01-05-2024, 10:52 PM | #5 | |
Just so that you know, these are mounted on stock 1940 Ford spindles utilizing only the spacers/adapters to put discs on stock Ford spindles, sold by all of the normal suppliers. Coop . |
01-05-2024, 11:52 PM | #6 |
01-06-2024, 09:03 AM | #7 |
I have only used the 46-48 hubs. They position the drums so the shoes are in the right place. They also have wide flanges so the wheels are supported if using Ford 5 1/2 pattern. The Buick drum mounting surface is not wide enough to do so.
The drum needs to carefully be centered when cutting the center. You will not need to re-balance if done right. Do not cut any of the iron liner. Just relieve the alum. |
01-07-2024, 12:15 AM | #8 |
ok good so im looking for 46-47-48 front hubs
01-08-2024, 12:32 AM | #9 |
There are a couple styles of the '46-'48 outside flange hubs. I prefer the one that is totally flat on the drum side as I drill and tap the bolt pattern in the hub and use 1/2-20 gr8 tap bolts for studs.
