07-18-2012, 10:45 PM | #1 |
39 conv hinge to door fasteners
Were the hinges originally riveted to the doors on these cars? Mine look to be riveted on as I don't see a screw slot, just looks like a flat head rivet.
07-21-2012, 04:03 PM | #2 |
Re: 39 conv hinge to door fasteners
Mine are screwed in with allen head screws. I know the screws are not original, but I think the threaded portion is.
07-21-2012, 04:26 PM | #3 |
07-22-2012, 08:38 AM | #4 |
Your door hinge, door side, should be riveted to the the door frame. you should also notice a small tack weld on the hinge to frame also. This is done to prevent the door from loosening and sagging as it is continually closed while slammed shut. The A pillar side hinge is the removable hinge and attached with bolts.
dickspadaro.com |
07-22-2012, 04:36 PM | #5 | |
