04-24-2021, 08:43 AM | #1 |
Do these front drum/hubs have a center "hub cap" to keep dirt out of the grease?
Do these front drum/hubs have a center "hub cap" to keep dirt out of the grease? And if so, tap in or screw in? Think 39 up Lincoln drum/hub?
Regards, Todd 1936 FORD Tudor Slantback "cajunhotrodder" on instagram/youtube |
04-24-2021, 08:51 AM | #2 |
Re: Do these front drum/hubs have a center "hub cap" to keep dirt out of the grease?
They should. Those hubs use the tap in type
04-24-2021, 09:15 AM | #3 |
You MUST install dust caps or calamity will ensue. Check the inner hub for threads and you'll know for certain what type of cap you need.
04-24-2021, 09:47 AM | #4 |
No caps on my 40 Ford back axle.....they need it
04-24-2021, 09:48 AM | #5 |
There never were caps fitted to the rear axle (drums).
04-24-2021, 09:55 AM | #6 |
04-24-2021, 10:17 AM | #7 |
I would bet you can find what you need on the "HELP!" rack at your FLAPS.
04-24-2021, 10:25 AM | #8 |
Thanks Tub, headed out to the shop now w/my caliper to see what size and to finish up my draglink install.
04-24-2021, 11:25 AM | #9 |
the first installation of press in caps can need some force, just pounding on the dome of the cap will dent it, a piece of pipe that rests against the ridge will help it seat square and without damage, ( i have a piece of exhaust pipe that has the 2 inner diameters that i need, hit it with large dead blow plastic hammer)
04-24-2021, 11:57 AM | #10 |
Have you tried 46-48 ford ?
04-24-2021, 12:00 PM | #11 |
the non threaded ones are an odd size, not found at local stores. gotta go to a ford vendor
04-24-2021, 12:39 PM | #12 |
Well here is the size, thanks again Gents
04-24-2021, 01:40 PM | #13 |
04-24-2021, 02:39 PM | #14 | |
That drum actually appears to be a '42-'48 FORD drum/hub. DD |
