Old 01-15-2018, 04:16 PM   #1
jessicajhrs
Default 1932 Ford Sedan/Tudor Original
City: GADSDEN
State: Alabama
Price: 26,500
-1932 Ford Tudor/Sedan full fendered, all Henry ford steel.
-Good Solid build-able car.
-This is an original V8 car/chassis with visible 18 series number stamped on chassis with matching title in hand.
-Original '32 V8 block partially disassembled
-Complete car comes with extra original parts (please email to see more photo's)
-Door jams are clean with no rust, as well as no rust in the rear wheel wells or subrails.
Only issues with car are listed below:
-missing driver side door garnish molding
-front splash apron is bent on the drivers side
-center cross member has been cut for an unknown reason
-rust on the lower drivers side cowl
-damage on drivers side rear fender, the bead of the fender is split on top
-damage to the rear right fender, the bead of the fender has torn about 6in long
-passenger front fender has damage right when it meets the running board and directly on top of the fender has bead split
This is an overall SOLID car. The car comes with extra original '32 parts, if you are interested and want more information I can provide more photo's, please message me ONLY if seriously interested.
jessicajhrs is offline   Reply With Quote
Old 02-07-2018, 11:29 AM   #2
jessicajhrs
Default Re: 1932 Ford Sedan/Tudor Original
Ttt
Old 03-07-2018, 02:29 PM   #3
jessicajhrs
ttt
Old 04-23-2018, 09:12 AM   #4
jessicajhrs
tttt
