Old 08-18-2016, 12:49 PM   #1
fordhistory
Default Pickup bed strips
Does anybody make pickup bed strips with at least one end formed?
In other words, on all of the new bed strips I see, both ends are squared off..., you can see the cross-section of the bed strip at both ends.
I want to lay the strips on top of the bed wood, not recessed into the wood, so I need one end formed down, so-to-speak.
I suppose I could cut, weld, and pound the ends on the bed strips that I've seen, but I'd rather buy factory-made strips, if they are available.
Henry
fordhistory is offline   Reply With Quote
Old 08-18-2016, 01:36 PM   #2
Krylon32
Default Re: Pickup bed strips
You may be able to order them a little bit long. When I got my 32 box from Mack Hills the back end of the strips was flattened. I shortened the box and was perplexed as how to flatten the shortened strips on one end. I took them to a company with a metal sheer and it turned out that in the sheering process it flattened the end perfectly.
Krylon32 is offline   Reply With Quote
Old 08-18-2016, 04:09 PM   #3
Russ/40
Russ/40's Avatar
The stainless ones I purchased for my "A" were as Krylon32 mentions above. I think I got them from Brattons.
Russ/40 is offline   Reply With Quote
Old 08-18-2016, 05:29 PM   #4
fordhistory
Thanks, guys! That helps me.
