Old 04-22-2021, 07:49 AM   #1
marshall k
Default 37 4dr window glass pattern
Greetings: Any ideas where I can purchase front window door glass patterns? Both of mine have missing sections. The companies I have contacted want to sell the glass, which I understand, however, I have a local glass shop that can cut the glass. Thanks for your time.
marshall k is offline   Reply With Quote
Old 04-22-2021, 08:08 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 37 4dr window glass pattern
Using what you have still existing plus the form where the glass sits, a pattern can be made out of cardboard or plywood to fit.
I have done this in the past to provide a pattern to the glass cutter.
Make note of the fore and aft position of the bottom channel.
Old 04-22-2021, 08:15 AM   #3
marshall k
The front sections are what is missing and the fact that the window moves slightly to the rear before lowering make me think I would be guessing to the shape of the front of the glass .
