Old 05-05-2015, 09:36 PM   #1
30aadoodlebug
30aadoodlebug's Avatar
Default Vacuum Wiper rebuild needed? Or something else?
Hey All,
So I'm the recent new owner of a barn find 1930 Tudor. The car has sat in a barn since 1956, and is in incredible condition considering the amount of time that it sat. Other than the generator, the only thing that is not working is the vacuum wiper system. It's pretty rusted, and I'm wondering if it needs to be rebuilt, or if it just needs a new rubber hose running from the cowl fitting to the wiper motor itself. That being said, could I need a rebuilt vacuum motor? or is my initial thought the fix. Also, if I do need to rebuild the motor, how would I go about it, as I have not been able to find any literature on it in any of my books.
Thanks,
Jon
30aadoodlebug is offline   Reply With Quote
Old 05-06-2015, 07:20 AM   #2
RonC
RonC's Avatar
Default Re: Vacuum Wiper rebuild needed? Or something else?
post a picture. Vacuum motors don't rust. Maybe you have an electric motor?
RonC is offline   Reply With Quote
Old 05-06-2015, 08:47 AM   #3
1930artdeco
1930artdeco's Avatar
You don't need the wiper if you don't drive in the rain. But if you do, then I use Rain-X. It will work better and I have found the water beads up and off normally on the windshield due to being vertical. You may want to cap the system temporarily to prevent any vacuum leaks.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 05-07-2015, 05:24 AM   #4
RonC
RonC's Avatar
Never go anywhere without rain-x. Does away with needing a functioning wiper
Old 05-07-2015, 08:18 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
Pictures needed.
Old 05-07-2015, 09:32 PM   #6
30aadoodlebug
Sorry for the delayed reply, I'm in the middle of law school finals so they are taking most of my time. I removed the wiper motor off the car. Also, in talking to my father (another a enthusiest) he said something about a rebuild kit. I looked them up, and they only cost about $10, so I think this might be the route to go. Any ways, here are some shots of the motor.
Old 05-07-2015, 10:09 PM   #7
RonC
RonC's Avatar
Don't open it unless you have too. Soak it in 3 and 1 oil first and work the shaft back and forth. It may only need oil
Old 05-07-2015, 10:23 PM   #8
Henry1953
Henry1953's Avatar
Check out WiperMan.com
Henry1953 is offline   Reply With Quote
Old 05-08-2015, 08:04 AM   #9
oldbike99
oldbike99's Avatar
It is my understanding that the available kits do not fit that early style wiper motor with the "screw on" tin cover. The gasket kit does fit. As suggested, oil it up and try it first.
oldbike99 is offline   Reply With Quote
Old 05-08-2015, 03:17 PM   #10
Redbird
Redbird's Avatar
Jon, Mine didn't work either. Someone on the forum told me to disconnect the vacuum hose, find a short piece of hose, add a few drops of 3 n 1 oil and blow it in while working the wiper back and forth. I did that, started up the car, and now works fine.
Redbird is offline   Reply With Quote
Old 05-09-2015, 06:29 PM   #11
gpits68
gpits68's Avatar
Looks like an original vaccum motor to me . I have been told the originals had the 2 screws on the cover like yours . I recently had mine torn apart and repaired , Mine had pitting inside on the area where it moves back and forth . I smoothed out the raised pits and cleaned everything and coated with 3 in 1 oil and replaced gasket . It works well . It must have no leaks .
gpits68 is offline   Reply With Quote
Old 05-09-2015, 07:31 PM   #12
glenn in camino
glenn in camino's Avatar
Get some Rainex.
glenn in camino is offline   Reply With Quote
Old 05-09-2015, 07:55 PM   #13
oldbike99
oldbike99's Avatar
I agree that Rainex is a good product, but the question was how to get the wiper to function. It may not do a great job, but I too, want my wiper to work.
Old 05-12-2015, 03:07 PM   #14
30aadoodlebug
Thanks all for the replies. Yes, I don't plan on driving my A in the rain (and if I do I'll use Rainex), but like any tinkerer it bothers me that it doesn't work.
Old 05-12-2015, 04:05 PM   #15
CarlG
CarlG's Avatar
Since mine is a manual wiper, it only works when I do.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-12-2015, 06:07 PM   #16
Jon-Ohio
Are there any technical web sites covering vacuum wiper rebuilding ?
Jon - in Ohio
Jon-Ohio is offline   Reply With Quote
Old 05-12-2015, 08:48 PM   #17
jojofilo88
jojofilo88's Avatar
This was a highly, non technical way of fixing mine, but I did take mine apart and oiled everything up. It wasn't too difficult and I got to see how it all worked. I cleaned the insides and oiled it again, then put it back together and it worked.
Driving to the Beardsley Cider Mill show this weekend was incredibly humid, so I ended up needing the wiper. Doesn't work nearly as well as a modern wiper, but definitely is effective!
Give that a shot first...maybe it just needs a good cleaning.
Joe
jojofilo88 is offline   Reply With Quote
Old 05-13-2015, 07:55 AM   #18
30aadoodlebug
Jon-Ohio, I found this on youtube, and it seems rather comprehensive.
https://www.youtube.com/watch?v=0hqe4xw0z8M
Jon- in Massachusetts
Old 05-14-2015, 10:32 PM   #19
30aadoodlebug
So, problem found. I did as everyone said and saturated the motor with 3-in-1 oil. This freed the wiper, but it still wasn't working. I decided to check the line from the firewall to the motor, and sure enough, it was the original fabric hose that was dried and split. I threw on a new rubber hose, and we're up And running. The reason for this wiper working and being so important is that here in Massachusetts, the wiper must function in order to pass inspection. Tomorrow I will find out if it will do so.
Thanks again for all of the feedback!
Jon
