01-27-2019, 03:27 PM | #61 |
Re: OK! Oldtimers, Gimme your best answer, Stuck Engine
"While at this point warranty might be a moot point, can't hurt to talk to them." Said redmodelt.
At this point it can't hurt to verify what is actually stuck! Then talk to the builder if necessary. |
01-27-2019, 04:40 PM | #62 |
I,m 90% sure it is the rear main. you can check that by dropping the pan and cap. This is not a new problem. You have to leave more clearance on the rear main or put a oil grove in the upper insert.
01-28-2019, 09:55 PM | #63 |
remove oil pan remove rod caps and find which piston is stuck if non are go to mains. once you find the stuck piston drive up and out with a dowel.
