Old 03-04-2021, 10:08 AM   #1
Licensed to kill
Licensed to kill's Avatar
Default Radius rod rubber ball replacement.
My car has the rubber ball radius rod repair on it and the ball is pooched so I am replacing it. Should it go on dry or lube it?. If it is to be lubed, lube inside, outside or both?. If so, regular grease or???.
Licensed to kill is offline   Reply With Quote
Old 03-04-2021, 10:18 AM   #2
Will N
Will N's Avatar
Default Re: Radius rod rubber ball replacement.
The original design had a felt pad for catching oil that leaked past the rear main, and the socket for the ball had a hole that allowed the oil to lube the joint. I think that the replacement socket for the rubber ball has no hole to allow the oil in. Oil might degrade the rubber ball over time, so I'd vote that you put it on dry.
Will N is offline   Reply With Quote
Old 03-04-2021, 10:27 AM   #3
Arlyn Bieber
The rubber ball is designed for the V-8 not Model A. Don't mess with Henry's design, install the original.
Arlyn Bieber is offline   Reply With Quote
Old 03-04-2021, 10:36 AM   #4
31Tudor
31Tudor's Avatar
I would grease both the inside and outside. The ball will have some movement, so a lubed ball is better. Then I think I would look at the original set up and go with that when you have the chance. The rubber ball kind of hides or masks a real worn ball, sometimes.
31Tudor is offline   Reply With Quote
Old 03-04-2021, 11:07 AM   #5
katy
If greasing, use red rubber grease, it won't deteriorate the rubber.
Play it again Sam.
Old 03-04-2021, 04:51 PM   #6
antiquepa
antiquepa's Avatar
The easy way to install is to just set the solid part of ball onto surface and roll it over the ball, I Put one on my car probably 10 years ago and put grease on mine and it slid right on. All your doing is turning it inside out. Nothing is never easy!!
antiquepa is offline   Reply With Quote
Old 03-04-2021, 05:15 PM   #7
Bruce of MN
Bruce of MN's Avatar
The rubber ball on my car had pooched and I was very happy to discover that the stock parts went right on and cured the shimmy. The steel ball was fine and I donít know why the rubber ball was put on. I vote for stock!
Old 03-04-2021, 08:19 PM   #8
Jonvee
Mine came with the rubber ball also. Lots of shimmy. They had installed the two springs between the clam shells to make it fit. Ball deleted.
Jonvee is offline   Reply With Quote
Old 03-04-2021, 10:39 PM   #9
Licensed to kill
While i appreciate everyone that took the time to respond, I was actually only asking about lubrication of the ball, not how authentic the rubber ball is for a Model A or IF I should use the rubber ball. The car drove smooth as butter and straight down the road with the old rubber ball but the ball was torn and since i had it apart (to pull the engine/trans) I chose to replace the rubber ball and bolts. I decided to grease the inside and leave the outside dry.
Old 03-06-2021, 06:54 PM   #10
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
TMI (another case of To Much Information)
Old 03-07-2021, 06:53 PM   #11
Rodrelic
Same as motorcycle handle bars, dish soap lets them slide on and they are glued, won’t come off.
Maybe modern made rubber not work as good
Rodrelic is offline   Reply With Quote
