Old 07-13-2018, 01:06 PM   #1
dodgeo
dodgeo's Avatar
Default 34 roadster windshield flapping
The windshield on my 34 roadster flaps and will not stay in a normal shut
position or open. I have tightened the wing nut at the top until I am afraid
I will strip something, but no luck. Do you think I am missing a special
washer or something else at the top ? ,or is this just a result of repo [?]
parts not doing the job correctly ?
Thanks, Dodge
dodgeo is offline   Reply With Quote
Old 07-13-2018, 01:46 PM   #2
mfagan
mfagan's Avatar
Default Re: 34 roadster windshield flapping
Might check to see is cups are seating properly in the stanchions. The repro stachions I had originally had to remachined to fit properly. Also, do you have the rubber gasket along bottom edge?
Marvin Fagan
214-697-8430
mfagan is offline   Reply With Quote
Old 07-13-2018, 04:13 PM   #3
DavidG
DavidG's Avatar
Originally there was a spring steel 'wave' washer used with the wing nut.
Old 07-14-2018, 09:40 AM   #4
glennpm
glennpm's Avatar
I ran into this when assembling my 32 last year. I ended up buying metric spring washers and drilling them out. There are other options too included in the thread.
https://www.fordbarn.com/forum/showt...=spring+washer
and what I did within this same thread:
https://www.fordbarn.com/forum/showp...2&postcount=13
Glenn
Old 07-14-2018, 11:56 AM   #5
DavidG
DavidG's Avatar
A&L Parts Specialties in Canton, CT has excellent reproductions of the washers (they were used on Model As as well) and perhaps Roy Nacewicz does as well (fordbolts.com).
Old 07-14-2018, 12:01 PM   #6
glennpm
glennpm's Avatar
David’s contacts would be a much better solution Dodger.
Thanks David
Old 07-15-2018, 08:39 AM   #7
dodgeo
dodgeo's Avatar
Thanks for the info on the spring washer, as mine has just a plain thin flat one
installed. Hopefully that will solve the problem, but I also think that the
combination of original re-chromed stanchions and repo windshield parts
might be a cause of the looseness. Any thoughts about those parts ?
Old 07-15-2018, 08:48 AM   #8
glennpm
glennpm's Avatar
As long as you can get tight, flat contact between the nuts and stanchions, you will be fine.
Old 07-15-2018, 09:13 AM   #9
DavidG
DavidG's Avatar
dodgeo,
One other possibility given that you are using reproduction windshield components might be the cones that seat in the windshield posts. Some of our fellow hobbyists have encountered oversize/undersize issues with the reproduction cones.
