Old 04-18-2018, 01:14 AM   #1
wkuehnis
wkuehnis's Avatar
Default Can't identify my Briggs number
Hi,
on my Briggs-Fordor 3-window, I have a Briggs-plate with the number 3732942.
I never found anything about such a number.
What type of car do I have
Thanks for help
Willi
wkuehnis is offline   Reply With Quote
Old 04-18-2018, 06:55 AM   #2
Joop
Joop's Avatar
Default Re: Can't identify my Briggs number
Post a picture if you can
Joop is offline   Reply With Quote
Old 04-18-2018, 08:20 AM   #3
1930artdeco
1930artdeco's Avatar
If you are referring to your avatar, then you have a 155D for a townsedan. Not sure of the standard body#.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 04-18-2018, 09:13 AM   #4
wkuehnis
wkuehnis's Avatar
This evening,
I will post a picture of the Briggs-plate from the Firewall.
Willi
Old 04-18-2018, 09:33 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by Joop View Post
My guess is that you have a reproduction
tag with the engine/frame number on it
Mine is done this way.
Old 04-18-2018, 12:39 PM   #6
wkuehnis
wkuehnis's Avatar
Here is the photo of the plate
Old 04-18-2018, 12:59 PM   #7
Joop
Joop's Avatar
Aftermarket Tag
Old 04-18-2018, 02:15 PM   #8
juke joint johnny
juke joint johnny's Avatar
If your car was imported into Switzerland from another country
they might have used that as a Vin tag to match the details on the Title or Paperwork
juke joint johnny is offline   Reply With Quote
Old 04-18-2018, 11:19 PM   #9
wkuehnis
wkuehnis's Avatar
The engine number is:
A740 629
Willi
Old 04-18-2018, 11:52 PM   #10
Joop
Joop's Avatar
#740629
Old 04-19-2018, 12:24 AM   #11
wkuehnis
wkuehnis's Avatar
I think, the title or title number is not important, it's from Denmark.
There is only the Briggs number 3732942.
But: Do you think, I can find any other number on the car ? Till now, I have only seen this Briggs-Plate and the engine number.
Willi
Old 04-19-2018, 04:50 AM   #12
ccb360
Check under the floor mat on front passenger side body frame next to the door sill. That the location of the body tag on my '29 Briggs TS.
ccb360 is offline   Reply With Quote
Old 04-19-2018, 05:54 AM   #13
wkuehnis
wkuehnis's Avatar
OK, I will check it this evening.
Thanks
Old 04-19-2018, 07:04 AM   #14
Joop
Joop's Avatar
Tag
Old 04-19-2018, 07:06 AM   #15
Joop
Joop's Avatar
Old 04-19-2018, 08:36 AM   #16
Mike V. Florida
Number also on the frame.
Old 04-19-2018, 08:45 AM   #17
1930artdeco
Is it possible that engine #3732942 was in the car originally when registered and then was changed later on before you got the car? That happens here a lot, even my car is registered that way. Unfortunately, the only way to find the correct number is to raise the body off of the frame and check there.
Mike
1957 Country Sedan
Old 04-20-2018, 02:22 AM   #18
juke joint johnny
I bet that is the original engine and frame number , Sounds right for your car year ,
The engiine number you have now is a 1929 number .
This often happens Ford in the UK had a policy "Drive in the Dealership in the morning and come out in the afternoon with a exchange rebuilt engine"
Old 04-21-2018, 01:09 AM   #19
wkuehnis
wkuehnis's Avatar
I chdcked it there, but didn"t finf anything
Old 04-21-2018, 02:03 PM   #20
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Jist go to BRIGGS&STRATTON.COM
Bill Helping
"THE ASSISTANT GURU OF STUFF"
