Old 10-13-2024, 09:29 AM   #1
My23 T
Default Engine dies
I have a 23 T Touring(mostly original)
My problem is that after I start it and let it run for a few minutes when I turn the head lights on the engine back fires and dies immediately
Any thoughts Thanx
My23 T is offline   Reply With Quote
Old 10-14-2024, 10:01 AM   #2
Will N
Will N's Avatar
Default Re: Engine dies
I'm guessing you have your headlights wired to the magneto output? Sounds like there's a short in the headlight wiring that diverting all the mag power to ground. Trace all the headlight wires and check for broken insulation. Look closely in the headlight bulb sockets, as the wires in there can short out to the body of the socket.
Will N is offline   Reply With Quote
Old 10-14-2024, 03:06 PM   #3
rotorwrench
rotorwrench's Avatar
The model Ts pretty much switched to battery, generator, and starter systems in the 1919 time frame but the early set up was still available for a while. By 1923, they should have all been that way. Magneto lighting has to be in series from the switch to the the first light on the right side and then from the first light to the second with the final wire going to ground. This is the only way they will work and not short the mag out. If one bulb burns out then you lose both headlights just like an old Christmas tree light string.
The light switch is part of the ignition switch on the starter/generator cars. The magneto only cars had a switch on the firewall for lights and the horn also ran on the magneto. There could be a problem with the light switch or a shorted wire as previously mentioned and this is true for both systems. What you have will need to be tested for proper function and connections.
Old 10-20-2024, 08:21 PM   #4
My23 T
Lights work ok on mag just when switched to battery everything quits
Old 10-22-2024, 10:27 AM   #5
rotorwrench
The electrical system is relatively simple on model Ts. Get a good diagram and compare that to how your switch is connected. Check to see if it has the lights connected to the Mag in series or to the individual terminals on the ignition/light switch.
