03-21-2021, 10:33 AM | #1 |
Header gasket question?
Bought a complete set of gaskets for my 8BA. All seemed normal / expected until I’m ready to put headers back on the engine & I noticed the header gaskets are stamped concave on one side? Probably a stupid question but does it matter which surface that concave side goes against. With torque I gotta believe they’ll end up flat like the other side anyway. All previous header gaskets I’ve seen are flat on bot sides. Thoughts on this? Maybe just be a result of the Mfg. process ( tooling)?
Nomad |
03-21-2021, 10:58 AM | #2 |
Re: Header gasket question?
Are you sure they are not 'convex' ?
03-21-2021, 11:10 AM | #3 |
Anthony,
It may be that the gaskets just took a "set" after being stamped out and sitting on a shelf. No big deal. They will flatten out when bolted down. Would be neat if you could post a photo or two. |
03-21-2021, 11:55 AM | #4 |
Pics, sorry for pic size. Still can’t figure FB pic process☹️
Nomad |
03-21-2021, 12:14 PM | #5 |
I just purchased a felpro gasket set, the exhaust gaskets look the same as yours. Just from punching them out, they will flatten when installed.
Sometimes, ingenuity gets in the way of sense and sanity. |
03-21-2021, 12:30 PM | #6 |
Nomad |
03-21-2021, 02:48 PM | #7 |
That type of exhaust manifold gaskets are always that way. Just how they are stamped out. Does not matter a bit. I do suggest if you have some copper, or other, metalic antisieze to coat both sides of the gasket surface. That way they will survive if removed, for reuse. Otherwise they delaminate when removed, and it's a bear to scrape them off.
I wouldn't use RTV there. |
03-21-2021, 03:10 PM | #8 |
Those were punched with a die set that was getting dull. I have some old ones and they are flat. They will go flat and seal ok when clamped.
