04-28-2020, 09:33 PM | #1 |
Headlight resilver or repalace
I used the search function and "resilvering" headlight reflectors is not a popular subject at least in the last four years...
Is this due to better quality of the newer versions of reflectors available compared to resilver costs? I would like to keep the what I think are original reflectors but they are in bad shape as I'm pretty sure I can see the base metal behind the silver on one of them and the other has a bad parking light socket so kinda at a point where new versions seem to be the logical choice. The car is a family driver so not keeping to a judging standard. I do not drive at night and do not plan to but ya never know so not a must do project at this time just looking for options. I would like to run the lights during the daytime as "daylight running lights" and have a new set of incandescent bulbs to install but open to the LED options for bulbs as well. Thinking the LEDs would help lower the electrical load significantly which can only help increase the longevity of the newly installed 6 V pos grnd alt. THANKS AS ALWAYS!!! |
04-28-2020, 09:47 PM | #2 |
Re: Headlight resilver or repalace
I have a company locally that re-silvers reflectors but it is expensive and you need to have some good reflectors to start with. Unless you are restoring a Fine Point Car, I would buy some new ones from Brattons. Theirs have the correctly shaped and are the best available. There are other reproductions that are not correctly made and do not reflect the light correctly.
I would also suggest LED bulbs, much less currant draw and they work well. Brattons also sell LED head light bulbs. That is what I would do. Chris W. |
04-28-2020, 09:49 PM | #3 |
Cannot help with resilvering info.
There was a lot of discussion on LED headlights when Logo Light were 1st offered. For more info perhaps do a search. Most Led headlights do throw a ton more light, have a low current draw 1-2 amps per headlight. Down side is most if all do not focus into a pattern/beam like the correct incandescents. They throw light everywhere. I have them and like them specifically because I use them for daytime driving lights, rarely drive at night. They throw a very bright/very white light, so do not recreate the look of an incandescent. People really do notice and see you coming. If converting to LEDS, make sure you have good socket contacts, and good grounds, and connections. Otherwise they may flicker when driving. If converting to LED, consider adding a Third brakelight strip . I added one to the tailgate of my truck and have noticed a huge difference, people no longer look confused when I am slowing down, and more distance between me and them when slowing down/stopping. |
04-29-2020, 02:40 AM | #4 |
I am a fan of the idea of re-silvering the reflectors, but finding anyone to do it might be tricky. I hear good things about brattons reproduction reflectors.
One option for daytime running lights i explored is putting LED strips where the gasket between the glass and reflector is. You only need tiny wires to 'feed' LED's. In reality, the tests i have done so far haven't revealed much that is bright enough as "daytime running lights", electroluminescent wire wasn't quite bright enough to be a park light. But it that light placement is something to think about.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
04-29-2020, 07:12 AM | #5 |
To shed a little light I just did a some research, there are a few folks doing re Silvering.
I prefer originals so I choose Craig Riker in Ohio. 419-290-4442 Brattons reflectors are said to be very good too. Price is going to be a wash, Brattons are $99pr, Re Silvering is about the same. The third option is a fella in Ore who does a glass like coating, said to be more durable. This process is done over a nickel plating ( 2 processes) and is a bit more pricey with 2 steps. With reflectors re done and the higher output incandescent bulbs you might be suppressed, adjusted properly they should be very good. Consider LED tail lights too. Two if you don’t already have them. United Pacific Industries replacement lens style very bright.
Tim Downtown, Ca |
04-29-2020, 07:14 AM | #6 |
Bob Bidonde |
04-29-2020, 07:16 AM | #7 |
The "fella in Ore" is most likely Uvira. Google it. They electroplate aluminum onto the reflector and polish it. I had it done on my old Graham MANY years ago and the brightness approached a sealed beam headlight. Highly recommend it...
Frank |
04-29-2020, 08:29 AM | #8 |
Originals always. Resilvering prices are all over the board. I use Craig Riker as he is very fair with his prices and does great work and knows Model A's. Just had him restore two 28 headlights for me. Brattons might be good quality, but it cannot be an original reflector. If the seal is put in correctly, there should be no outside air hitting the reflector for it to tarnish.
"The more things change, the more they stay the same." |
04-29-2020, 08:57 AM | #9 |
I do not know anything about silver, would a good coat of polish or clearcoat prevent tarnish?
04-29-2020, 09:01 AM | #10 |
I was advised to you just regular old car wax on Nickel and Silver. Definetely don't want an abrasive.
04-29-2020, 09:08 AM | #11 |
I used Medallion Liquid Silver with fair results. Replates the silver, but a lot of exposed brass comes out rather orange, no matter how much you put on. Nushine and Jax are similar products.
Might work well enough for your use. I plan to nickel plate another pair I have and try it again, will probably turn out better. |
04-29-2020, 10:19 AM | #12 |
Don't go with the cheaper chrome ones. The new ones sold are the correct shape.
As a sample; https://www.snydersantiqueauto.com/P...hts/head-light
04-29-2020, 11:31 AM | #13 | |
Charlie Stephens |
04-29-2020, 12:42 PM | #14 |
As others have said, aluminum coated reflectors from Brattons are the way to go. Take a look at the graph and you can see that silver is slightly more reflective than aluminum by ~5% in the visible spectrum (between the poorly drawn lines). Also note that chrome is only ~60% reflective, no good. Given that silver will tarnish if not perfectly maintained, I'd still go with new Brattons reflectors. I have them and they are markedly better than the old chrome ones.
04-29-2020, 02:27 PM | #15 | |
www.whidbeymodelaclub.com |
04-29-2020, 05:13 PM | #16 | |
Brattons are not chrome plated. Chrome is not a good material for reflectors as chrome actually defuses the light. Bratton's are aluminum coated. Modern telescopes mirrors are coated with aluminum. This is the best material for reflectivity, Silver is next. You can polish silver, you use lamp black and a very soft cloth, like a piece of flannel. Lamp black is available at a good hardware store. Chris W. |
04-29-2020, 05:29 PM | #17 |
Try Ron's Corner in Missouri. 660-749-5473. He re-silvers my original mirrors. When they start to turn yellowish, polish with lamp black and flannel. Do not use any micro fiber cloth. It will scratch the silver surface.
04-29-2020, 06:16 PM | #18 |
04-29-2020, 08:51 PM | #19 |
I second the Uvira comment. Really nice quality
04-29-2020, 09:22 PM | #20 |
That is "precipitated Chalk"
From my handy "materials handbook" … Suspenso, of the Diamond Alkali Co., is a very white, grit-free precipitated Calcium Carbonate. There were several other trade names listed for similar ultra pure forms of the same chemical. I suspect that a compounding druggist would use this for creating pills. More info than you will ever need! Joe B |
