Old 10-07-2019, 08:27 AM   #1
Model T 1927
Model T 1927's Avatar
Default Model A intake on a Model T
Has anyone put a Model A Intake on a Model T? Will it fit or does it need to be modified?
Model T 1927 is offline   Reply With Quote
Old 10-07-2019, 11:44 AM   #2
Chris Haynes
Chris Haynes's Avatar
Default Re: Model A intake on a Model T
No way Jose. You would also have to change the exhaust manifold.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 10-07-2019, 12:50 PM   #3
gz
gz's Avatar
You sure can! People have been doing it for years. It is such a popular conversion that Snyder's even offers a whole kit to do the conversion-see the links I have attached for the whole kit or just the adapter plate.
The main part you need is the special adapter plate, everything else is readily available new or used. Some people use the Model A exhaust, some people make headers. If you don't want to use a stock Model A manifold, you can even get a Model A down draft manifold, etc. etc.
https://www.snydersantiqueauto.com/P...del-t/manifold
gz is offline   Reply With Quote
Old 10-07-2019, 02:23 PM   #4
Model T 1927
Thank you, I appreciate it very much. I will get the adapter and start on it. This is going to make things a lot easier for me.
Old 10-07-2019, 04:26 PM   #5
Scottio57
Scottio57's Avatar
When I first got my 26 Roadster it had an A intake and carb. And I hated it. I constantly pulling and cleaning plugs. It also had 14mm plugs and I changed them to the OEM plugs but they too would fowl in no time. I finally collected enough parts to put the T intake back on and I’m a lot happier. The A set up did not give me any more power just more problems.
Scottio57 is offline   Reply With Quote
Old 10-07-2019, 08:16 PM   #6
redmodelt
redmodelt's Avatar
You can use the 3 in one T copper faced gaskets and don't need the plate. The nice thing about the plate is that you can fit gland rings on both sides, but lots of people have done it without the plate. If you have a 26/27 with the tank in the cowl, good to go, but with the tank under the seat your fuel level is going to be lower then the carb most of the time unless you install a fuel pump or drop the carb down on a extension. You will also need to open the area where the manifolds slide on the 4 studs. You are also going to need to build a custom exhaust system.
Old 10-08-2019, 01:15 AM   #7
Dodge
If you use a Model B exhaust manifold it has almost the same downward angle of the Model
T exhaust manifold. Check it out. You see them on eBay
Dodge is offline   Reply With Quote
Old 10-12-2019, 07:32 AM   #8
blgitn
blgitn's Avatar
On my 27 RPU, I had to make a heat shield for the sediment bowl when I did this, even with headed wrap on the B manifold.
With a Lizzard head and stipe cam it was scary fast! I pushed the levers up when the GPS hit 60, but we were still climbing!
blgitn is offline   Reply With Quote
Old 01-12-2020, 01:37 PM   #9
blackbob
what Stipe cam did you use with the Lizard head? and what other mods? I asked over at the MTFCA but Lizards get a bad reception
http://modeltfordspeedster.blogspot.com/
http://strathbranspeedshop.blogspot.com/
makin a noise in the middle of nowhere
blackbob is offline   Reply With Quote
Old 01-12-2020, 07:52 PM   #10
blgitn
blgitn's Avatar
Bob,
It was a Stipe 280. I've heard the Lizzard stories too but mine was great! I should've pulled it off before I sold the truck.
R/ Roger.
