Old 08-17-2019, 03:08 PM   #41
Bored&Stroked
Bored&Stroked's Avatar
Default Re: FH Valve Springs
Frank - when you use a larger diameter spring than stock, you will not be able to assemble the engine the "easy way" - by dropping the whole valve, guide, spring and keeper assembly in from the top. You'll have to "assemble the springs" inside the valley area - which isn't a lot of fun and requires a set of tools designed for this specific task. It is by far easier to use Ford's method - where all you need is a good flathead "valve bar" and you don't have to worry about dropping retainers and keepers down into the bowels of the engine.
Old 08-17-2019, 03:17 PM   #42
frnkeore
frnkeore's Avatar
My guilds will be similar but, made of aluminum, with 1/2" aluminum bronze stock, drilled and reamed, pressed into them. I could put the PC type seals, directly on the bronze stock if, you think it helps.
I'm also considering a pressed in guild, with a shoulder, since I have to use 1 3/4 aluminum stock, to start with.
Does anyone use pressed in guilds?
Frank
Added:
B&S, I just saw your post after posting. I guess the pressed in guilds would go along with my spring use. Unless there a reason not to do it, I'll go with it.
frnkeore is offline   Reply With Quote
