Old 06-21-2019, 03:28 PM   #21
emf
emf's Avatar
Default Re: 54 Convertible Chrome Clips
Funny, but the number you quoted, 358397-S8 is also shown in my parts book in the tables for the convertible, but the photo of the part in the front of the book shows 358397-S. In either case, the part seems to be unavailable, regardless which PN you use. I may have to use a universal molding clip and drill new holes. At least it's all covered by the molding...
Frank
emf is offline   Reply With Quote
Old 06-21-2019, 03:35 PM   #22
emf
emf's Avatar
Your second photo, if showing the section to the side of the molding just behind the rear window, has newer looking hardware. Did you install this or was that there. Here are the photos of my car. I think they are about the same.
Old 06-21-2019, 04:30 PM   #23
KULTULZ
KULTULZ's Avatar
Post Re: 54 Convertible Chrome Clips
Frank
Both PN's will be the same fastener. The PN Suffix -S identifies it as a STANDARD HARDWARE PART. The 8 denotes the finish/color of the fastener.
If there is a large auto paint/body supply in your area, they should be able to give you a reasonable match (universal).
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 06-21-2019, 06:09 PM   #24
Merc Cruzer
Merc Cruzer's Avatar
Were the same clips used to install the chrome strip on the two door coupes? You might be able to find them in a salvage yard. Not too many convertibles in salvage yards these days.
Merc Cruzer is offline   Reply With Quote
Old 06-21-2019, 09:33 PM   #25
emf
emf's Avatar
Per the parts manual, convertibles were the only one to use this clip. Universal is probably the way to go. luckily, I have some time to make the decision...
Frank
Old 06-27-2019, 06:51 AM   #26
emf
emf's Avatar
Default Re: 54 Convertible Chrome Clips FOUND!!
Received an email over night that Restoration Supply in PA has found the clip I need. Will call today to purchase. Thanks for all the help and suggestions...
Frank
Old 06-27-2019, 09:15 AM   #27
54vicky
54vicky's Avatar
good to hear you have found the right part keep us updated
54vicky is offline   Reply With Quote
