Old 08-08-2017, 09:39 AM   #1
redmodelt
redmodelt's Avatar
Default 1948 H 226 engine head bolt torque and V8's
Quick question (ok two) what is the torque for the head bolts and does anyone have a chart to show proper order to tighten the bolts?
Thanks
Old 08-08-2017, 10:47 AM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: 1948 H 226 engine head bolt torque
Says 65-70lbs in the manual.
Old 08-08-2017, 07:14 PM   #3
redmodelt
redmodelt's Avatar
Thank you very much. Just what I needed.
Old 08-09-2017, 02:07 PM   #4
grumppyoldman
grumppyoldman's Avatar
Is that no. good for all flatheads V-8's too? Al
grumppyoldman is offline   Reply With Quote
Old 08-12-2017, 08:51 AM   #5
redmodelt
redmodelt's Avatar
Default Re: 1948 H 226 engine head bolt torque and V8's
Added V8 to title. I'll bump it and see if we can find out.
Old 08-12-2017, 09:41 AM   #6
JSeery
JSeery's Avatar
A little high for what a lot of people like for the v8. The thickness of the head surface on the v8 is fairly thin. Also that high a torque is not required to get a good head gasket seal. Around 55 works fine in most cases.
Old 08-12-2017, 09:51 AM   #7
grumppyoldman
Thanks for the reply JS, now that I've tightened mine to 60 ft. lbs. Al
Old 08-12-2017, 08:53 PM   #8
toby
toby's Avatar
Torque to 65-70 like the manual states. Also the manual states- 65-70 for the 8BA. Cylinder head nuts for both the 6 and the 8 is 50-55.
toby is offline   Reply With Quote
