Old 05-23-2012, 07:46 PM   #1
estout81
Default waterpunp bolt
Anybody have a pro or con on useing s/s bolts for inside pump to block?
Thanks,
Em
estout81 is offline   Reply With Quote
Old 05-23-2012, 08:04 PM   #2
habbott
Default Re: waterpunp bolt
I have had no problems doing it this way. Remove my pumps after 10 years in service had no problems removing s/s bolts.
habbott is offline   Reply With Quote
Old 05-23-2012, 09:05 PM   #3
Vergil
Vergil's Avatar
I use SS on my builds ...
Vergil
Bigger fonts to aid in reading
Vergil is offline   Reply With Quote
Old 05-23-2012, 09:34 PM   #4
37 Coupe
37 Coupe's Avatar
Thanks,
Em
I consider it a neccessity just make sure you use an anti-seize on the bolt. See you at Lancaster show.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 05-24-2012, 06:08 AM   #5
Vic Piano
Vic Piano's Avatar
I agree with all of the above, I use SS bolts on all the water pumps on our Flatheads. Like 37 Coupe says, make sure you use anti-seize on the SS bolts.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 05-24-2012, 07:24 AM   #6
G.M.
Make sure the bolts are not to long. I have seen a few that people used longer bolts that bottomed out and the gasket leaks. Also make sure the lock washer don't drop off the internal bolt and wind up stuck in the impeller. One of Skips customers had this happen last week. G.M.
www.fordcollector.com
Old 05-24-2012, 07:45 AM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
SS with anti seize on threads is the way to go for that one internal water pump bolt. It can be a real pita removing a plain steel bolt that has broken off inside the block. Also dealing with a plain steel bolt that has most of its hex head rusted away can also make you say some very bad words
John
Old 05-24-2012, 08:16 AM   #8
estout81
Thanks everyone for your advice. S/S it is! 37coupe, I plan on being there.
Thanks,
Em
