02-06-2021, 06:50 PM | #1 |
Next move??
SO, I drilled the holes I. The backs of the caps to use the compressed air to pop the caps off the shell’s, all three have rust at points around the inside perimeter of the shells and didn’t allow the pressure to pop the caps loose, SO what’s the next best way to remove the Stainless Steel caps now???
02-06-2021, 07:53 PM | #2 |
Re: Next move??
I would put them in your wifes oven and heat them up. Make that metal move a little bit. Let them cool down/ shrink down and try popping them off again.
02-06-2021, 08:01 PM | #3 |
Re: Next move??
If rust is the problem, I'd soak them in "Evapo-Rust" for a couple of days. It's the least invasive process I can think of.
02-06-2021, 08:14 PM | #4 |
Re: Next move??
I drill the hole close to the outside edge and use a blow nozzle with a rubber tip to seal tight. Have never failed to pop off.
02-06-2021, 08:40 PM | #5 |
Re: Next move??
Dude......not to be a smart ass BUT read my post!!! The inside edge of the shells are rusted through in one, two, three places and WILL NOT allow ANY air Pressure to build up behind the cap!!! THUS it just blew through the rusted through spots on the shell!!!! I’d like not to cut the shells BUT I think that’s the only way and not mess up the SS caps!!!
02-06-2021, 11:00 PM | #6 |
Re: Next move??
02-07-2021, 09:00 AM | #7 |
Re: Next move??
You have a choice, sacrifice the stainless part of the cap, or the metal part. since you want to restore the stainless part, it should be a no-brainer. I know that this means added expense to buy more hubcaps, but would you restore the stainless, and re-install the stainless on the steel part of the hub-caps that were sub-standard. ?
02-07-2021, 09:08 AM | #8 | |
Re: Next move??
Dale |
02-07-2021, 09:26 AM | #9 |
Re: Next move??
Notice this one has some holes rusted in it also.
02-07-2021, 09:58 AM | #10 |
Re: Next move??
Thanks Dale.....one of the four was “completely” rusted almost all the around so the SS cap came right off. Two of the remaining shells are really pretty good and the rusted spots could be welded and fix (I think) fairly easy??? SO I hate to cut them, the last one I don’t think is any great loss IF I had to cut it!!! SO I may try the “epoxy” suggestion on the two and cut the third!!!
02-07-2021, 10:50 AM | #11 |
Re: Next move??
You're welcome. As I'm sure you know that Ford Mercury cap is tough to find as opposed to the regular Mercury cap as shown in my photo.
Dale |
02-07-2021, 11:08 AM | #12 | |
Re: Next move??
Yes I do, this is my second set. We have a set on our 10/38 produced Town Sedan and I just happened upon this set a few weeks ago!! Only the third “Full” set we’ve had the opportunity to buy in 46 years. This is third set out of the first two. The first set my Dad unfortunately let pass back in 1974!!! |
02-07-2021, 11:16 AM | #13 |
Re: Next move??
Just a quick question, are the steel shells the same on both early and late caps?
Dale |
02-07-2021, 11:48 AM | #14 |
Re: Next move??
At this point, I cannot tell you for sure? I have a standard Mercury 8 cap on the spare in the Sedan and was going to use that for the one Cap I have that basically had NO shell so will let you know when that time comes!! I’ve worked that cap trying to get it ready for sanding and buffing BUT still need to get the other three off and the same treatment SO.......time!!!! This is the one I have worked so far.....both under the Ford and Mercury were smashed in and scratched so getting close with it!!!!
02-07-2021, 11:48 AM | #15 |
Re: Next move??
At this point, I cannot tell you for sure? I have a standard Mercury 8 cap on the spare in the Sedan and was going to use that for the one Cap I have that basically had NO shell so will let you know when that time comes!! I’ve worked that cap trying to get it ready for sanding and buffing BUT still need to get the other three off and the same treatment SO.......time!!!! This is the one I have worked so far.....both under the Ford and Mercury were smashed in and scratched so getting close with it!!!! Don’t know why up loads from my phone are sideways??
02-07-2021, 11:57 AM | #16 |
Re: Next move??
Coming along nicely.
02-07-2021, 01:15 PM | #17 |
Re: Next move??
https://www.googleadservices.com/pag...BAgCEBc&adurl=
How about using one of there tire bead blasters maybe make an adapter out of a small bucket to the back of your hubcap with the hubcap sitting on a bucket so it blows the stainless into the bucket or similar. These things work great. Good luck. |
02-07-2021, 02:29 PM | #18 | |
Re: Next move??
Dale |
02-07-2021, 04:10 PM | #19 | |
Re: Next move??
02-08-2021, 12:59 PM | #20 |
Re: Next move??
You have gotten some good advice as far as getting the skin off, i'd like to share one of my methods to get a perfect, distortion free reflective surface on a round or domed part. I use stones ranging from (approx) 1000 grit (hard black Arkansas) to 400 grit (fine India) ,and i have the stones water jet cut to a slightly larger radius than the part that i am working on. This curved surface allows you to all the minute highs and lows. The hubcap pictured has been metal worked and polished with abrasives, it still needs to be buffed. Hope this helps.
Tom |
