06-14-2021, 02:38 PM | #1 |
Scraping sound when turning 35 ford
Hi guys; noticed a metal to metal sound when turning on my 35 ford.
Removed brake drums found brake shoe metal scraping inside brake drum on both sides. Cleaned and inspected , repacked wheel bearings. Bearings had correct adjustment. ( not loose). Springs are all on, no obvious problem. Any ideas? |
06-14-2021, 02:45 PM | #2 |
Re: Scraping sound when turning 35 ford
My first idea is mixed-and-matched parts. Any chance you can send good pics of front and rear of the brakes?
How many miles have you put on the car?
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
06-14-2021, 03:02 PM | #3 |
Backing plates may be worn where the shoes ride . Backing plates are bent . Check the wheel bearings adjustment. JMO.
06-15-2021, 03:46 PM | #4 |
