08-26-2011, 12:22 PM | #21 |
Re: A closer look at dyno data: what gives the most bang for the buck?
Actually the the low end performance or torque is very good. The intake duration is 255 the exhaust duration is 252 . No doubt many like this grind . The last I looked at Bills site it was listed as The most popular regrind. I haven't looked at the site lately but I am well pleased with my cam. I have no agenda here. Anyone can do as they please, my lifetime experience is that the 3.78 gear ratio is best suited for the model A. My model A's are only fun cars and fullfill all of my expectations.
08-27-2011, 09:39 AM | #22 |
Three cheers for the people who run dyno tests and share their results. Regarding torque versus horsepower, my guess is that the torque results are for the serious engine people, and horsepower is for bragging.
There are a couple of things that might account for different results observed by different people, and maybe results by the same person. One is that engine temperature never seems to be reported, and might not even be controlled or measured. Another is that with Model A tests, the timing is usually set at a fixed position for the entire run-up. This means that maximum performance is being measured only for the RPMs where the timing is optimum. |
08-27-2011, 03:02 PM | #23 |
Richard,
'one is that engine temp never seems to be reported'... I read the charts/stats/comments that were provided. One thing what stuck out, to me, is that the dyno tests were done at a CONSTANT temp..i.e.- 180! Got me to wandering if I shouldn't take out my 160 stat and put in 180 ? My gut tell me that if my engine is running 180 (as in dyno tests done), that my engine will operate more efficiently, etc.... i.e.- wear more evenly, burn fuel more evenly, use oil more evenly(less polution in oil) ??? Last edited by hardtimes; 08-27-2011 at 03:04 PM. Reason: add.. |
08-27-2011, 11:14 PM | #24 | |
08-28-2011, 12:09 AM | #25 | |
08-28-2011, 12:48 PM | #26 |
08-28-2011, 01:38 PM | #27 |
Bassman,
I believe that you are correct! As my B tends to run a 'little' cool anyway (new rad/new pump/new block) I feel that she is not running maximum efficiency. Going to a 180, can't do but help IMO. Last edited by hardtimes; 08-28-2011 at 01:40 PM. Reason: ad.. |
