09-07-2016, 04:48 PM | #1 |
36 wiring
How is the headlite harness routed on a 36 roadster? Thanks, Jack
09-07-2016, 05:42 PM | #2 |
Re: 36 wiring
09-07-2016, 05:42 PM | #3 |
Re: 36 wiring
From the headlight it goes through the screw that holds the headlight onto the fender stay/support and then through a hole in the fender support/fender which is where is connects into the main loom which plugs into the light switch.
09-07-2016, 05:47 PM | #4 |
Re: 36 wiring
I don't think my copy and paste worked too good, however, to continue from weemarks reply, the wiring from left to right headlights runs along bottom of radiator [originally there is two clips soldered at seam] above the bottom hoses.
09-07-2016, 09:31 PM | #5 |
Re: 36 wiring
Thanks, Brian. That is what I was looking for. Jack
09-07-2016, 09:49 PM | #6 |
Re: 36 wiring
09-08-2016, 08:18 AM | #7 |
Re: 36 wiring
Yes, excellent resource. I was just curious about the location of the wiring between the headlights.
