Old 02-07-2015, 09:30 AM   #1
Tim Armstrong
Tim Armstrong's Avatar
Default 30 vs 31 front fenders
Is it possible to remove the apron extension on a 30 fender and use it on a 31?
Tim Armstrong is offline   Reply With Quote
Old 02-07-2015, 09:45 AM   #2
Kevin in NJ
Default Re: 30 vs 31 front fenders
The flange may need to be extended to have enough room to make room for the bolt holes. The flange on some of the 30 fenders I have seen were not long enough to allow for the elongated bolt holes used on the 31. Yes, Ford had oval holes to allow for room with fitting.
Kevin in NJ is offline   Reply With Quote
Old 02-07-2015, 09:46 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Yes but you will need to extend that flange by about .250-.350 where you can drill the holes to bolt the one-piece aprons to.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-07-2015, 09:47 AM   #4
BRENT in 10-uh-C
( guess Kevin types faster than I do! )
BRENT in 10-uh-C
