Old 05-10-2014, 05:22 PM   #1
gilitos
gilitos's Avatar
Default Most efficient way to remove a camshaft
I'm trying to replace my cam and lifters without pulling the head. Is it possible? The springs still load the lifters even with the keepers removed, and to remove the springs I will have to remove the head and lift the valves. Any ideas, or will I simply have to bite the bullet and take off the head?
gilitos is offline   Reply With Quote
Old 05-10-2014, 05:36 PM   #2
mshmodela
mshmodela's Avatar
Default Re: Most efficient way to remove a camshaft
According to Les Andrew's Book, page 1-46 it can be removed via the front timing gear cover (yeah removing that).
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 05-10-2014, 06:03 PM   #3
colin1928
colin1928's Avatar
You need to remove the head and valves
do not forget to remove the oil pump gear
also the fuel pump if it is a B
Colin
colin1928 is offline   Reply With Quote
Old 05-10-2014, 06:22 PM   #4
1931 flamingo
1931 flamingo's Avatar
Also, keep the valves in order, along with everything else. FWIW
Paul in CT
Old 05-10-2014, 07:10 PM   #5
larrys40
I have done it before without removing the head. I had a 3/4 cam in one and wasn't happy with it , switched back to a stock b grind
Remove valve cover
Remove all valve keepers and springs push valves up pull up lifters and wire up to hold them up
Remove distributor and oil pump drive gear
Remove radiator front timing cover
And them camshaft
Install in reverse and reset all valve clearances
An evening job
Larry shepard
larrys40 is offline   Reply With Quote
